Update MultipassBitmap
On 18/10/2011 at 00:44, xxxxxxxx wrote:
Cinema 4D Version: 12
Platform:
Hy there,I want to set floating-point values to an allocated MultipassBitmap. I find it strange, that there is no method to set floating-point values, I can just see `
Bool SetPixel(LONG x, LONG y, LONG r, LONG g, LONG b);
`from the BaseBitmap class.
After a while of searching I then figured out, that I could maybe use the GetLine and SetLine if casted to a VPBuffer. Now I use the example code from the invert-image example to read a line into a buffer and set the buffer back.
When I set it back, it always returns FALSE, so the SetLine is not working. For testing purpose I didn't change the buffer that I read out, but that doesn't change the outcome. I do all this within a TagData plugin's message-callback method.
What can I do?
Is there another method I can use to update a MultipassBitmap with Real values?
Is it possible, to write data to a Bitmap residing in a Bitmap shader?
Thank you,
maxx
On 19/10/2011 at 02:58, xxxxxxxx wrote:
Here is a simple example how to create and access a 32bit floating point MultipassBitmap:
Bool MenuTest::Execute(BaseDocument *doc) { MultipassBitmap *mbmp = NULL; SReal *buffer = NULL; mbmp = MultipassBitmap::Alloc(512, 512, COLORMODE_RGBf); if (!mbmp) goto Error; buffer = GeAllocType(SReal, 512*3); if (!buffer) goto Error; //fill a line; I used a brightness over 100% (4.0) for (LONG i=0; i<512*3; i++) buffer[i] = 4.0; //cast the SReal buffer into UCHAR; inc parameter is 3*4bytes (3*32bit) because of floating point image format for (LONG y=0; y<512; y++) if (!mbmp->SetPixelCnt(0, y, 512, (UCHAR* )buffer, 12, COLORMODE_RGBf, PIXELCNT_0)) goto Error; ShowBitmap(mbmp); MultipassBitmap::Free(mbmp); GeFree(buffer); return TRUE; Error: MultipassBitmap::Free(mbmp); GeFree(buffer); return FALSE; }
Unfortunatly not.
cheers,
Matthias
On 19/10/2011 at 09:18, xxxxxxxx wrote:
Thanks a lot for the example!
maxx
