On 14/10/2011 at 10:08, xxxxxxxx wrote:
Is BaseList2D.FindCTrack(id) broken or am I just mis-understanding it ?
The documents say it takes 1 argument, id, which is a c4d.DescID but every time I try to supply the argument, I get an error :
"TypeError: FindCTrack() takes no arguments (1 given)"
Sample code :
id = c4d.DescID(c4d.ID_BASEOBJECT_REL_POSITION) obj.FindCTrack(id)
BaseList2D.FindCTrack(id) is the only way I can think to find a particular track if there is more than one with the same ID, for example 2 tracks for PSR constraint 'weight' parameter have the same ID.
Any help appreciated.
On 15/10/2011 at 13:20, xxxxxxxx wrote:
Yes you're right, BaseList2D.FindCTrack() is currently broken in R13. It will be fixed in an upcoming update.
On 15/10/2011 at 15:29, xxxxxxxx wrote:
It is broken in R12 as well.
On 16/10/2011 at 03:10, xxxxxxxx wrote:
Ok, thanks for the confirmation guys.
