On 15/09/2011 at 17:17, xxxxxxxx wrote:
I am making a simple script that does the following
1. Runs through a simple loop that iterates different scene cameras (controlled with User data ID:17) 2. Changes the Renderoutput path (c4d.RDATA_PATH) based upon this loop 3. Renders the image with this filename.
I am able to get steps 1 and 3 working fine. However 2 doesnt update in the render settings. The c4d.RDATA_PATH function won't actually write the change to the render setting. Is there a better method for approching this problem. I thought that there would be a render function that had a path argument, rather than getting it from the render setting.
I know this is somthing really simple, but i cant seem to find out what i am doing wrong guys.
import c4d from c4d import bitmaps, documents c4d.CallCommand(1024314) # Clear Python Log c4d.CallCommand(1022604) # Open Python Log def PreviewLoop() : doc = documents.GetActiveDocument() rd = doc.GetActiveRenderData().GetData() for i in xrange(5) : rd[c4d.RDATA_PATH] = r'C: emp0' + str(i+1) #Iterate Render Path op[c4d.ID_USERDATA, 17] = i+4 #Iterate Seleceted Camera c4d.EventAdd() print str(rd[c4d.RDATA_PATH]) # Preview path Confirmation bmp = bitmaps.BaseBitmap() bmp.Init(x=1024, y=576, depth=32) #Initiate Render Resolution documents.RenderDocument(doc, rd, bmp, c4d.RENDERFLAGS_EXTERNAL) bitmaps.ShowBitmap(bmp) #Launch Picture Viewer PreviewLoop() print 'Done!'
Any ideas? thanks.
On 15/09/2011 at 18:34, xxxxxxxx wrote:
Looks like i solved it
Had something to do with rd = doc.GetActiveRenderData(). I moved the GetData() to the documents.RenderDocument argument...
Here is the updated code.
import c4d from c4d import bitmaps, documents c4d.CallCommand(1024314) # Clear Python Log c4d.CallCommand(1022604) # Open Python Log def PreviewLoop() : doc = documents.GetActiveDocument() rd = doc.GetActiveRenderData() op[c4d.ID_USERDATA, 14] = 0 # Disable any Analaglyph Preview settings print 'Rendering Preview...' # Preview Confirmation. for i in xrange(5) : rd[c4d.RDATA_PATH] = r'C:\ViewX emp0' + str(i+1) #Iterate Render Path op[c4d.ID_USERDATA, 17] = i+4 #Iterate Seleceted Camera c4d.EventAdd() print str(rd[c4d.RDATA_PATH]) # Preview path Confirmation bmp = bitmaps.BaseBitmap() bmp.Init(x=1024, y=576, depth=32) #Initiate Render Resolution documents.RenderDocument(doc, rd.GetData(), bmp, c4d.RENDERFLAGS_EXTERNAL) bitmaps.ShowBitmap(bmp) #Launch Picture Viewer PreviewLoop() print 'Done!'
