On 09/09/2011 at 05:33, xxxxxxxx wrote:
where are the definitions of "order" in R13 for methode HPBToMatrix??
_<_dt id="c4d.utils.hpbtomatrix"_>_ c4d.utils.HPBToMatrix( hpb , order ) e.g. utils.HPBToMatrix(myhpb,c4d. ROT_YXZGLOBAL) will result in "module object has no attribute 'ROT_YXZGLOBAL'.
And if I set direct numeric values from R12, the effect in R13 is not the same as in R12:
eg.: utils.HPBToMatrix(myhpb,0 _)
Has anybody an idea?
Meinolf _
On 09/09/2011 at 07:23, xxxxxxxx wrote:
I can only confirm that it does not work as before. We do need SDK snippets asap for this and the new SplineGUI.
Cheers Lennart
On 09/09/2011 at 08:35, xxxxxxxx wrote:
It looks like the new definitions are found in the coffee.h file.
EXAMPLE:
c4d.utils.HPBToMatrix(myhpb, c4d.ROTATIONORDER_ZXYGLOBAL)
On 09/09/2011 at 08:50, xxxxxxxx wrote:
Ah, good call. Interesting how the rotations are based from the vector…. v.x = pitch v.y = heading etc…
On 09/09/2011 at 09:35, xxxxxxxx wrote:
Jepp, this is fine. Thank you! Now my plugin works well with R13.
To keep scripts compatible with R12 we now have to make extra code:
if (c4d.GetC4DVersion()>=13000) : c4dROT_HPB=c4d.ROTATIONORDER_HPB c4dROT_YXZGLOBAL=c4d.ROTATIONORDER_YXZGLOBAL else: c4dROT_HPB=c4d.ROT_HPB c4dROT_YXZGLOBAL=c4d.ROT_YXZGLOBAL
...and we have to exchange first and second component of the vector...
if (c4d.GetC4DVersion()>=13000) : v=c4d.Vector(cmd['y'],cmd['x'],cmd['z']) else: v=c4d.Vector(cmd['x'],cmd['y'],cmd['z'])
Meinolf
On 09/09/2011 at 16:09, xxxxxxxx wrote:
It looks as if: HPBToMatrix(vector) still can be used (only 1 argument) Is this a legacy mode that will be dropped at a time later?
Also, are we sure the "swapped" x and y vectors are correct and not a bug?
PS. R12 GetOptimalAngle(vectorA , vectorB) is changed. It now need a 3:rd argument, rotation order to run (no legacy mode) R13 is: GetOptimalAngle(vectorA , vectorB, c4d.ROTATIONORDER_XYZGLOBAL) I haven't checked if the vectors are swapped as in the HPBToMatrix() DS.
