On 06/09/2011 at 07:20, xxxxxxxx wrote:
User Information: Cinema 4D Version: Platform: Language(s) : C++ ;
--------- Hi there,
I am trying to write a plugin, that draws certain values (per vertex) over existing objects. I am not sure what the best way is to archive that. I could write a shader, but the information I want drawn is more a helper when modeling takes place.
The latest idea was to create a Tag similar to VertexMap or WeightMap. I am not sure, though, how to draw over the existing object with my own colors. Does anybody know, how Weight and VertexMap Tags do this? Is this actually possible from within a plugin?
Best Timm
On 06/09/2011 at 07:35, xxxxxxxx wrote:
I'm interested in this as well.
If you choose to write a new Tag, then I guess you could draw the object yourself in the TagData->Draw() function. In this case however, you would also need to disable the drawing of the original object, and I don't know how that could be done.
Keep us updated on your progress!
Best regards /Filip
On 12/09/2011 at 06:08, xxxxxxxx wrote:
The vertexmap tag uses internal core functions. What you can do is to write your own scene hook and override the SceneHookData::DisplayControl, SceneHookData::InitDisplayControl SceneHookData::FreeDisplayControl functions. They allow to set object display mode and vertex colors.
On 28/09/2011 at 03:02, xxxxxxxx wrote:
Thanks, that helps a lot! For everybody else interested in this topic, I also found these two threads:
https://plugincafe.maxon.net/topic/5992/6110_drawing-color-information-object-overlay https://plugincafe.maxon.net/topic/5636/5667_display-control
And on a similar topic: Is it also possible to override drawing altogether to allow for my own default shading algorithms? Like a chrome view mode, or Gooch?
On 28/09/2011 at 03:12, xxxxxxxx wrote:
Originally posted by xxxxxxxx And on a similar topic: Is it also possible to override drawing altogether to allow for my own default shading algorithms? Like a chrome view mode, or Gooch?
Only through the EOGL library. Unfortunatly we can't provide documentation and support for the time being. If you feel brave you can take a look at the gl_test_object.cpp , gl_material.cpp , visualize_channel.cpp , VPInvertImage.cpp and vpstereo.cpp SDK examples though
The EOGL classes and structures reside within c4d_gl.h.
