On 04/09/2011 at 18:49, xxxxxxxx wrote:
Is there any way to run simple Coffee commands from within Python. I ask because i already have a working Python script but would like to add these simple commands as well...
a) delete unused materials/textures b) delete unused layers c) Launch the Python console window.
This is very easy in coffee, as there is a script listener ala maya mel. there is no such thing for python.
I suspect the answer is no and you will refer me to the documentation, however i have searched there and I cant see where i can run these commands...
Thank you.
On 05/09/2011 at 02:26, xxxxxxxx wrote:
Hi, Coffee Plugins and Coffee Scripts have an ID so you can use c4d,CallCommand(id) to execute them. Just open the command manager, search your coffee plugin/script and pass the ID of them to the function. Cheers, Sebastian
On 05/09/2011 at 02:28, xxxxxxxx wrote:
Those CallCommand ID's are the same all over. So you can run the Script Log to get the ID's and use them in Py adding c4d. before them.
I.e:
c4d.CallCommand(100004760) # Remove Unused Layers
Cheers Lennart
On 05/09/2011 at 03:19, xxxxxxxx wrote:
Thanks so much guys. Exactly what i was after.
