get selection poligon vertex and perform a scaling
    On 26/08/2011 at 03:09, xxxxxxxx wrote:
    Cinema 4D Version:   12
    Platform:
    I'm using c.o.f.f.e.e. (no pytohon, no c++) i'm in polygon mode i would to do these things:
    1. enable menu plugin if the user is in polygon mode and has selected a poligon
    2. get all the list of polygon selected
    3. then perform a scaling but only for the X axis
      very big thanks!
    On 30/08/2011 at 09:42, xxxxxxxx wrote:
    The state of the menu entry is controled via the MenuPlugin::GetState method. Override it for your own plugins. The other points are explained in my example.
    class MPPlugin : MenuPlugin
      public:
          MPPlugin();
          GetID();
          GetName();
          GetState();
          GetHelp();
          Execute(doc);
    MPPlugin::MPPlugin()
      super();
    MPPlugin::GetID()
      return 1001150;
    MPPlugin::GetState()
      var doc = GetActiveDocument();
      if (!doc) return 0;
      // is polygon mode checked
      if (!IsCommandChecked(12187)) return 0;
      // is there an selected object and is it a polygon object
      var op = doc->GetActiveObject();
      if (!op || op->GetType() != Opolygon) return 0;
      // is at least one polyogn selected
      var sel = op->GetPolygonSelection();
      if (sel->GetCount() == 0) return 0;
      return CMD_ENABLED;
    MPPlugin::GetName()
      return "Scale Test";
    MPPlugin::GetHelp()
    MPPlugin::Execute(doc)
      if (sel->GetCount() == 0) return;
      var fcnt = op->GetPolygonCount();
      var vcnt = op->GetPointCount();
      // create a vertex index array to store selection states for vertices of selected polygons
      var vidx = new(array,vcnt);
      if (!vidx) return;
      var i = 0;
      // initialize the array
      for (i=0; i<vcnt; i++)
          vidx[i] = FALSE;
      // converts polygon selection into point selection
      for (i=0; i<fcnt; i++)
          if (sel->IsSelected(i))
              var poly = op->GetPolygon(i);
              vidx[poly->a] = TRUE;
              vidx[poly->b] = TRUE;
              vidx[poly->c] = TRUE;
              vidx[poly->d] = TRUE;        }
      // go through the vertices and do something (e.g scale)
          if (vidx[i])
              var vertex = op->GetPoint(i);
              // do something with vertex
              vertex.x *= 5.0;
              //vertex.y *= 2.0;
              //vertex.z *= 3.0;
              op->SetPoint(i, vertex);
      // must be called for object and editor update
      op->Message(MSG_UPDATE);
      EventAdd();
      Register(MPPlugin);
    cheers,
    Matthias
