On 20/08/2011 at 07:57, xxxxxxxx wrote:
Trying to set DateTime from external file (exif) Any pointer how to format the DateTimeData() object? What I have are strings that need to go "into" the: mytimedata = DateTimeData()
The code here prints a skyobject datetime, I'd like to go the other way using my strings as base.
Cheers Lennart
import c4d from c4d import gui, DateTimeData def main() : sky = doc.GetFirstObject() skybc = sky.GetDataInstance() skydtd = skybc.GetData(c4d.SKY_DATE_TIME) print DateTimeData.GetDateTime(skydtd)
On 21/08/2011 at 04:53, xxxxxxxx wrote:
Hi, here is a sample code how to parse a string into a DateTimeData object. And here you get a list of the directives for the string parser (strptime) : http://docs.python.org/library/datetime.html#strftime-strptime-behavior
import c4d import datetime from datetime import datetime from c4d import gui, DateTimeData def main() : sky = doc.GetFirstObject() skybc = sky.GetDataInstance() td=datetime.strptime('16.07.2011 03:37:12',"%d.%m.%Y %H:%M:%S") dtd=DateTimeData() #set the datetime.datetime object to the DateTimeData object dtd.SetDateTime(td) skybc.SetData(c4d.SKY_DATE_TIME,dtd) c4d.EventAdd() main()
On 21/08/2011 at 05:31, xxxxxxxx wrote:
Great, many thanks.
