Creating a sound Track
    On 13/08/2011 at 09:40, xxxxxxxx wrote:
    Cinema 4D Version:   12
    Platform:   Windows  ;
    I can't get a sound file to load into a sound track properly using Python. So I'm giving it a try with C++. But I'm running having problems creating a sound track.
    C4D is crashing on me. And I don't know what I'm doing wrong:
    Bool SimplePlugin::Execute(BaseDocument *doc)
      BaseObject *sphere = BaseObject::Alloc(Osphere);
      doc->InsertObject(sphere, NULL, NULL); // Add it to the OM
      CTrack *soundtrack = CTrack::Alloc(sphere,DescLevel(CTsound,DTYPE_LONG,0));  //SDK says this: CTrack::Alloc(op,DescLevel(ID,ID,0))
      sphere->InsertTrackSorted(soundtrack); //This crashes C4D!!!
      //Then I need to load a sound file from my desktop into the sound field
      EventAdd();
      return true;
    I think I might be using the wrong code in the second Alloc ID parameter.
    Can anyone offer any help on creating a sound track and loading a sound file into it?
    On 13/08/2011 at 12:42, xxxxxxxx wrote:
    I figured out where my the crashing mistake was.
    Now that I can successfully create a sound track. How do I load a file into it?
    If I use the base container method. It just loads the file's text information into the sound field. But it doesn't actually load the file into the track:
      CTrack *soundtrack = CTrack::Alloc(sphere,DescLevel(CTsound,CTsound,0));
      Filename file = GeGetC4DPath(C4D_PATH_DESKTOP) + "moviemix.wav";
      BaseContainer bc = soundtrack->GetData();
      bc.SetFilename(CID_SOUND_NAME, file);
      soundtrack->SetData(bc);
      EventAdd();
      return true;
    This is the same problem I was having with Python.
    On 13/08/2011 at 15:38, xxxxxxxx wrote:
    Here's how I do it:
        // Add Sound track to Null object
      CTrack*        track =        CTrack::Alloc(nullObj, DescID(DescLevel(ID_ANIM_SOUND,ID_ANIM_SOUND,0L)));
      if (!track)                return ErrorException::OOMThrow(EE_NODIALOG, logging, GeLoadString(IPPERR_MEMORY_TEXT), "IPPLoader.AddSound.track");
      nullObj->InsertTrackSorted(track);
      if (storeUndoLoad)        baseDocument->AddUndo(UNDOTYPE_NEW, track);
      // Set Start Time and Sound
      // - Unofficial means to load audio file into SoundTrack
      SoundTrack*    sdata =        (SoundTrack* )track->GetNodeData();
      if (!sdata)                return ErrorException::Throw(EE_NODIALOG, logging, GeLoadString(IPPERR_MEMORY_TEXT), "IPPLoader.AddSound.sdata");
      if (!sdata->sound)        return ErrorException::Throw(EE_NODIALOG, logging, GeLoadString(IPPERR_MEMORY_TEXT), "IPPLoader.AddSound.sdata->sound");
      if (!sdata->sound->Load(sname))    return ErrorException::Throw(EE_NODIALOG, logging, GeLoadString(IPPERR_MEMORY_TEXT), "IPPLoader.AddSound.sdata->sound->Load(fn)");
      track->SetParameter(DescID(DescLevel(CID_SOUND_START, DTYPE_TIME,0L)), baseDocument->GetTime(), DESCFLAGS_SET_0);
      //track->SetParameter(DescID(DescLevel(CID_SOUND_NAME, DTYPE_STRING,0L)), sname.GetFileString(), DESCFLAGS_SET_0);
      track->SetParameter(DescLevel(CID_SOUND_NAME),sname.GetFileString(),DESCFLAGS_SET_0);
      track->SetName(sname.GetFileString());
      EventAdd();
    On 13/08/2011 at 15:39, xxxxxxxx wrote:
    Note that ID_ANIM_SOUND is typdef'd from CTsound for backward compatibility; just use CTsound.
    On 13/08/2011 at 16:11, xxxxxxxx wrote:
    Thanks Robert.
    I'm getting all kinds of undefined errors with that code from things like: SoundTrack, ErrorException, logging,sname, EE_NODIALOG, etc..)
    Can you tell me what includes you're using?
    On 13/08/2011 at 17:12, xxxxxxxx wrote:
    Never mind.
    I eventually managed to get it working.
    Using your example. I found out that SetParameter works:
      CTrack *track = CTrack::Alloc(sphere, DescID(DescLevel(CTsound,CTsound,0L)));
      sphere->InsertTrackSorted(track);
      track->SetParameter(DescID(DescLevel(CID_SOUND_START, DTYPE_TIME,0L)), doc->GetTime(), DESCFLAGS_SET_0);
      track->SetParameter(DescLevel(CID_SOUND_NAME),file,DESCFLAGS_SET_0);
      EventAdd();
      return true;
    Now I just need to see if there's a way to make it work in Python.
    Thanks Robert.🍺
    On 20/10/2011 at 15:09, xxxxxxxx wrote:
    Here's my method for Python:
    Download the script here:
    http://cl.ly/1J002V0y3o0q1c3v2B20
    I also explain it here:
    http://vimeo.com/30851937
