On 11/08/2011 at 07:01, xxxxxxxx wrote:
User Information: Cinema 4D Version: R12 Platform: Windows ; Language(s) : C++ ;
--------- Hi,
I can't convert the c4d sdk in VC 2010 Express under Windows 7. It always shows me there were erros while converting. And taking a look into the Project-explorer, I only see this:
Do I need another version of Visual Studio or what is wrong ?
Thanks,
On 11/08/2011 at 07:46, xxxxxxxx wrote:
Originally posted by xxxxxxxx <ADDRESS> User Information: Cinema 4D Version: R12 Platform: Windows ; Language(s) : C++ ; --------- </ADDRESS> Hi,I can't convert the c4d sdk in VC 2010 Express under Windows 7. It always shows me there were erros while converting. And taking a look into the Project-explorer, I only see this:[...] Do I need another version of Visual Studio or what is wrong ?Thanks,
Have a look at this place: http://www.gamelogicdesign.com/index.php/articles/getting-started-with-cinema4d-sdk-and-visual-studio-2008-express/
It was about VS 2008 express, but should give you the necessary hints to modify the projects...
Best regards,
Wilfried
On 15/08/2011 at 11:13, xxxxxxxx wrote:
Not sure if you solved your problem already. I had the same problems a few days ago. I was missing the proper Windows SDK. I downloaded an SDK from MS (7.1.7600.30514_x86_GRMSDK_EN_DVD.iso), but that solved the problem only half way. Another problem seems to be the 64-Bit integration in VS2010 express. There's a bugfix release from microsoft (GRMSDKX_EN_DVD.iso), which finally solved my problems.
Hope this was of any help, Andreas
On 30/12/2011 at 11:27, xxxxxxxx wrote:
Same problem here, I'll try your fix.
On 30/12/2011 at 16:30, xxxxxxxx wrote:
This worked for me: Visual Studio 2010 kann das Cinema4DSDK so auf win 7 64 bit nicht verarbeiten und kompilieren. Es bricht dann immer mit Fehlermeldungen ab. Es muss zwingend noch das win 7 SDK installiert werden, damit Visual Studio 10 mit dem C4d-SDK funktioniert. Dazu müssen folgende Schritte eingehalten werden:
