On 09/08/2011 at 15:56, xxxxxxxx wrote:
User Information: Cinema 4D Version: 12+ Platform: Language(s) : C++ ; PYTHON ;
--------- In my .str file I have several entries with names for different cameras film properties. Some names by tradition use the " sign. (Inch) I.e. one film format is called: 1/1.8"
However I'm not able to get it correct in my .str file such as:
SDOF_FILM_17 "1/1.8",""";
Any idea if this is possible to do in the .str file? (It's the res/string_us/description/my.str I'm talking about)
Cheers Lennart
On 09/08/2011 at 17:25, xxxxxxxx wrote:
You might need to include the Unicode representation in the .str file but escape sequences should work.
"1/1.8",""" is two strings. I don't think you can do that. I have never seen multiple strings associated with a single string resource description using a comma separator. You should try it like this:
"1/1.8""
On 09/08/2011 at 17:44, xxxxxxxx wrote:
Thanks Robert for checking. Didn't work thou, it then reports an error for the next line.
Afaik "1/1.8"""; should work (no comma as I had before) the little research I've done so far.
But the .str file itself is maybe not C++ ? I'm using it in a Python plug but thought the descriptions are C++ ?
On 09/08/2011 at 19:21, xxxxxxxx wrote:
" 1/1.8 " "" won't work since you've already closed the quoted string (bolded)
The .str file is just a file used by C4D. It is not C++. You will need the Unicode representation instead. The escape character is still used but uses the numerical reference instead (copyright symbol, for instance) :
\u00a9
\u represents a Unicode sequence and the 4 digits are the value in hexadecimal. \u0022 is the double quote. So, you might need to represent the string resource like this:
SDOF_FILM_17 "1/1.8\u0022";
On 09/08/2011 at 19:28, xxxxxxxx wrote:
This is a trick. But it appears that the way that C4D displays characters in it's GUI's. You can create the "illusion" of a double quote by using two single quotes next to each other like this:
SDOF_FILM_17 "1/1.8 '' ";
The forum here doesn't seem to display single quotes differently either. So here's the same line of code written phonetically: SDOF_FILM_17 (DoubleQuotes)1/1.8(singleQuote)(singleQuote)(DoubleQuote).
I tried this in both a C++ and a Python tag plugin. And they both work fine under a Windows environment. And the next entries in the .str file also work properly. But since you're on a Mac. I don't know if this trick will work for you.
*Oops- Cross posted with Robert
On 09/08/2011 at 19:30, xxxxxxxx wrote:
Thanks Robert! Works a treat! Was hunting Unicode on Wiki and didn't get it, now I do thanks to your snippet. Earlier example was also a typo. it should be: "1.8""; That actually works within Cinema itself, like userdata strings. (Even thou the ending ; (the semicolon) is "blue" in coffee script.
On 09/08/2011 at 19:32, xxxxxxxx wrote:
Oh, missed your post Scott, thanks for your input as well
