NodeData.InitAttr() inside of ObjectData.Execute()
On 06/08/2011 at 13:24, xxxxxxxx wrote:
hey everyone! i was wondering if it is ok to put a NodeData.InitAttr() method inside of the ObjectData.Execute() function? i am hoping to init the hide flag of an attribute in my .res file. depending on an if() statment. Sound workable to anyone? or am i breaking the laws of the universe here. thanks in advance for the help!
On 06/08/2011 at 14:19, xxxxxxxx wrote:
I don't understand what you are trying to do. You can't set the hide-flag within the InitAttr method afaik , and if so, please tell me how.
On 07/08/2011 at 21:59, xxxxxxxx wrote:
After doing a bit more research, i think the part im confused about is exactly how c4d applies a python based GeDialog for a plugin object. It seems very straightforward to create the GeDialog Class, but how does one initialize that dialog with all its c4d gagdets into the instance of your plugin object?
EDIT: readaing some more. GeDialog is solely to display GUI dialogs. I'm just not sure how to create dynamic data entries that will appear and disappear, using python.
On 08/08/2011 at 02:46, xxxxxxxx wrote:
For plugin objects and tags whoose guis are displayed in the AM, you use descriptions.
You can't create dynamic descriptions in python.
On 10/08/2011 at 13:41, xxxxxxxx wrote:
bummer. hopefully r13 helps with this! i noticed they are adding tabs functionality to description files in there, so that should do what i need. thanks for the reply Niklas.
