On 05/08/2011 at 15:10, xxxxxxxx wrote:
User Information: Cinema 4D Version: 12 Platform: Windows ; Mac ; Language(s) : C.O.F.F.E.E ; C++ ; XPRESSO ; PYTHON ;
--------- hey! just wondering if it is "legal" to add if statements to .res descritotion files for a custom plugin. The reason i ask is because im trying to figure out the best way to make a attribute of an object plugin disappear and appear based upon what other attributes are turned on and off. (for example, a boolean switch will display and hide a menu within the plugin). if this is not a good idea, mabye someone could point me in the right direction. Thanks for the help in advance guys! _Alex
On 05/08/2011 at 15:26, xxxxxxxx wrote:
No.
To do what you want to do involves using dynamic descriptions through the plugin's GetDDescription() method.
On 06/08/2011 at 08:31, xxxxxxxx wrote:
Robert,
Do you happen to have an example of that? I can't picture how to do this in my head.
On 06/08/2011 at 12:56, xxxxxxxx wrote:
I think i saw some info in the C++ API docs about dynamic descriptions. thanks for the answer! and if anyone has an example, it would definitely be helpful!
edit:
found something in the _ _ lib_description.h _ _ file.
if you look up dynamic descriptions in the API you can also find a bunch of cool stuff. thanks guys!
On 06/08/2011 at 14:19, xxxxxxxx wrote:
As it happens, today I did a short tut on exactly this on my site. You can find it here: http://www.microbion.co.uk/graphics/c4d/cookbook-2.htm
Should give you all you need to make this work.
On 06/08/2011 at 15:37, xxxxxxxx wrote:
Thanks for the tutorial Steve.
I have a tag plugin I made using a bunch of common tasks that I use as a reference for how to set up the various GUI items. And I'm going to add this to it.
On 07/08/2011 at 01:30, xxxxxxxx wrote:
Cheers Scott. Glad you found it useful. (I write these for my own benefit as much as anyone's - I can never remember the exact steps to take when I need to do something like this for a new plugin.)
