ViewportSelect
On 02/08/2011 at 11:00, xxxxxxxx wrote:
Cinema 4D Version:   R12
Platform:   Windows  ; Mac  ;
Is it okay to use ViewportSelect in Draw() in a tooldata plugin?
I am trying to implement the following code but vps->Init() keeps returning FALSE.
  BaseObject* op = doc->GetActiveObject();
  if(!op) return TOOLDRAW_0;
  //CONVERT TO POLYGON OBJECT
  PolygonObject *objPoly = ToPoly(op);
  if(!objPoly) return TOOLDRAW_0;
  //HELPER VARIABLES
  //Viewport Dimensions
  LONG left, top, right, bottom, width, height;
  bd->GetFrame(&left, &top, &right, &bottom);
  width                    = right - left + 1;
  height                    = bottom - top + 1;
  LONG editorMode            = doc->GetMode();
  Vector * points            = objPoly->GetPointW();
  EditorWindow *win        = bd->GetEditorWindow();
  Real radius                = 50;
  Vector color            = Vector(1,1,1);
  LONG x = cursorX;
  LONG y = cursorY;
  GePrint("X: " + LongToString(x) + " Y: " + LongToString(y));
  //Viewport Select Variables
  AutoAlloc<ViewportSelect> vps;
  GePrint("1");
#ifdef C4D_R12
  if (!vps || !vps->Init(width, height, bd, objPoly, editorMode, TRUE, VIEWPORTSELECTFLAGS_0))
      GePrint("NO INIT");
      return TOOLDRAW_0;
#else
  if (!vps || !vps->Init(width, height, bd, objPoly, editorMode, TRUE, 0)) return TOOLDRAW_0;
#endif
  vps->SetBrushRadius(radius);
  bd->SetPen(color);
  bd->SetMatrix_Matrix(objPoly, Matrix());
  vps->ShowHotspot(win, x, y);
  ViewportPixel *vpPoint    = vps->GetNearestPoint(objPoly, x, y, radius, FALSE, NULL, NULL);
  //DeSelect based on pixel radius
  LONG xmin = x - radius;
  LONG xmax = x + radius;
  LONG ymin = y - radius;
  LONG ymax = y + radius;
  LONG            iy;
  ViewportPixel*    vp            = NULL;
  Vector            origin        = Vector(x, y, 0);
  Vector            current;
  Vector            dist;
  Real            dis;
  for(LONG ix = xmin; ix < xmax; ++ix)
      for(iy = ymin; iy  < ymax; ++iy)
          current        = Vector(ix, iy, 0);
          dist        = origin - current;
          dis            = Len(dist);
          if (dis < radius)
                  vp = vps->GetPixelInfoPoint(ix, iy);
                  bd->DrawHandle(points[vp->i], DRAWHANDLE_BIG, NOCLIP_Z);
                  GePrint("DRAW HANDLE");
  return    TOOLDRAW_AXIS|TOOLDRAW_HANDLES;
Thanks,  Shawn
On 11/08/2011 at 06:08, xxxxxxxx wrote:
I think it's a bad idea to do this in Draw(). You can always store the data obtained by ViewPortSelect in member variables of your tool class and trigger a viewport redraw with DrawViews. Draw will be called then.
cheers,
Matthias
