Priority issues reading splines for a TagObject
    On 26/07/2011 at 16:07, xxxxxxxx wrote:
    Cinema 4D Version:   11.5
    Platform:   Windows  ;
    Hi again,
    I'm working on a Spline IK system. Over all it works fine, but there's a one-frame lag with the splines it's reading. So far, the only way it calculates correctly is if I set the priority of my tag to  Generator.
    Here's the code I'm using:
    #define ID_GSPLINEIK 1027376
    #include "c4d.h"
    #include "c4d_symbols.h"
    #include "customgui_splinecontrol.h"//for spline thingies, range-mapped stuff
    #include "c4d_customdatatype.h"
    #include "lib_splinehelp.h"
    #include "ogsplineik.h"
    class GSplineIK : public TagData{
    public:
    virtual LONG			Execute				(PluginTag* tag, BaseDocument* doc, BaseObject* op, BaseThread* bt, LONG priority, LONG flags);
    virtual Bool			Message				(GeListNode *node, LONG type, void *t_data);
    virtual Bool			GetDEnabling		(GeListNode *node, const DescID &id, const GeData &t_data, LONG flags, const BaseContainer *itemdesc);
    static NodeData		*Alloc				(void)	{ return gNew GSplineIK; }
    LONG GSplineIK::Execute(PluginTag* tag, BaseDocument* doc, BaseObject* op, BaseThread* bt, LONG priority, LONG flags){
    BaseContainer	*data		= tag->GetDataInstance();
    BaseObject		*rail		= data->GetObjectLink(SPLIK_RAIL, doc),
    *spl		= data->GetObjectLink(SPLIK_SPLINE, doc);
    if (!spl) return EXECUTION_RESULT_OK;//don't run without a spline
      LONG i,
    j,
    jointcount	= 0,
    splseg = data->GetLong(SPLIK_SPLINESEG),
    railseg = data->GetLong(SPLIK_RAILSEG);
    spl->Message(MSG_POINTS_CHANGED);//doesn't seem to help...
    SplineObject*	splobj = spl->GetRealSpline();
    splobj->InitLength(splseg);//used to get dimensions of spline
    BaseObject		*temp		= (BaseObject* )data->GetLink(SPLIK_TIP, doc),
    *tempnext;
    AtomArray		*list		= AtomArray::Alloc();
    while(temp != NULL){// get a list of objects in the chain
    jointcount ++;
    list->Append(temp);
    if(temp == op) break;
    temp = temp->GetUp();
    if(jointcount < 2){// don't calculate unless there's at least two objects in the chain
    list->Free(list);
      Matrix joint1Mg,
    joint2Mg,
    jointupMg,
    railMg;
      Vector jointrot;
    Real			*bonelen,
    start,
    end,
    splinelen = splobj->GetLength();
    SplineHelp	*railh = SplineHelp::Alloc();//used to get matrixes/vectors from spline
    railh->InitSpline(rail, 0.0, FALSE, TRUE, FALSE, FALSE);//rail spline
    SplineHelp	*splh = SplineHelp::Alloc();
    if(rail != NULL){//use rail spline if it exists, ignore if it doesn't
    splh->InitSpline(spl, 0.0, rail, TRUE, FALSE, FALSE);
    }else{
    splh->InitSpline(spl);
    if(data->GetLong(SPLIK_LENGTHMODE) == SPLIK_USEPERCENT){
      start	= data->GetReal(SPLIK_PERCENTOFF),
      end		= data->GetReal(SPLIK_PERCENTLEN);
    }else{
    if(splinelen > 0.0){//catch division by zero
    start	= data->GetReal(SPLIK_METEROFF)/splinelen;
    end		= data->GetReal(SPLIK_METERLEN)/splinelen;
    }else{
    start	= 0.0;
    end		= 1.0;
    temp = (BaseObject* )list->GetIndex(jointcount - 1);//GET HIGHEST ITEM FROM CHAIN
    temp->SetMg(splh->GetMatrix(start + 0.0/(jointcount - 1), splseg, TRUE, TRUE));//GET MATRIX FOR CALCULATIONS
      // matrix calculations here, change coordinates of hierarchy
    railh->Free(railh);
    splh->Free(splh);
    list->Free(list);
    splobj->FreeLength();
    Bool GSplineIK::Message(GeListNode *node, LONG type, void *t_data){
    if(type == MSG_DESCRIPTION_CHECKDRAGANDDROP){
    DescriptionCheckDragAndDrop *dcu = static_cast<DescriptionCheckDragAndDrop*>(t_data);
    switch (dcu->id[0].id){
    case SPLIK_SPLINE:
    case SPLIK_RAIL:
    dcu->result = dcu->element->GetInfo() & OBJECT_ISSPLINE;
    return TRUE;
    return TRUE;
    Bool GSplineIK::GetDEnabling(GeListNode *node, const DescID &id,const GeData &t_data,LONG flags,const BaseContainer *itemdesc)
    itemdesc; flags; t_data;
    BaseContainer &data = *((BaseObject* )node)->GetDataInstance();
    switch (id[0].id){
    case SPLIK_PERCENTOFF:	return (data.GetLong(SPLIK_LENGTHMODE) == SPLIK_USEPERCENT);
    case SPLIK_PERCENTLEN:	return (data.GetLong(SPLIK_LENGTHMODE) == SPLIK_USEPERCENT);
    case SPLIK_METEROFF:	return (data.GetLong(SPLIK_LENGTHMODE) == SPLIK_USEMETER);
    case SPLIK_METERLEN:	return (data.GetLong(SPLIK_LENGTHMODE) == SPLIK_USEMETER); }
    return TRUE;
    Bool RegisterGSplineIK(void){
    return RegisterTagPlugin(ID_GSPLINEIK,"GRig SplineIK",
    TAG_EXPRESSION|TAG_VISIBLE|TAG_MULTIPLE,
    GSplineIK::Alloc,"Ogsplineik",
    "gsplineik_icon.tif", 0);
    This is my first time using SplineHelp Class and I'm guessing it might be causing the issue, though I can't be sure.
    Has anyone experienced something similar to my problem?
    regards,
    -gene
