UV Coordinates
On 25/07/2011 at 15:31, xxxxxxxx wrote:
Hy there,
is there a way to retrieve UV coordinates for certain coordinates?
I have for example a sphere with a bitmap projected onto it. Now I would like to read out the UV coordinates for a certain point that I project onto the sphere.
Thank you,
maxx
On 27/07/2011 at 06:54, xxxxxxxx wrote:
Hi maxx_981, for example you can take a look at c4d.UVWTag.GetSlow. With a polygon ID you can get the UVW coordinates for this polygon and get the coordinates for the points. Cheers, Seb
On 27/07/2011 at 09:10, xxxxxxxx wrote:
Ok, thank you. I will check it out!
maxx
On 27/07/2011 at 14:13, xxxxxxxx wrote:
Ok, I can retrieve the correct polygon-id now and read out the uvwdict with the UV coordinates.
Do I have to interpolate the values or is there too a function around for this?Thank you,
maxx
On 28/07/2011 at 16:24, xxxxxxxx wrote:
Seems I have to make it a habit to resolve my questions by myself ;)
I found the barycentric-coordinates available from the GeRayCollider. So I do the interpolation with these.
maxx
