On 22/07/2011 at 13:57, xxxxxxxx wrote:
User Information: Cinema 4D Version: 12 Platform: Windows ; Language(s) : C++ ;
--------- Hi,
i have a problem with te Collider Engine. I want to fill the Collider Cache with all Objects in the Scene, to make a hiddenline Test.
So all is ok with my function, but if there is a Null-Objekct in the Scene, than my memory usage increases rapidly so that the plugin finaly crashes the computer if I don't stop. I think the problem is in FillColliderCache which i have mostly taken from the SDK help.
I don't know why this happens and how to work around this. Maybe you have an Idea ?
Thanks,
Mackel
For the hiddenlineTest I use this:
while(opc){ GePrint(opc->GetName()); if(!FillColliderCache(cCache, opc)) GePrint("Fail Cache"); else{ GePrint(opc->GetName()); for(int i = 0; i <= 100; i++){ if(opc->GetType() != Onull) //make shure it is not my code in here that causes the problem { //Do some stuff
if(cEngine->DoRayCollide(cCache,wtail, !oray,op != opc ? ldist : (ldist-0.1)) != COL_OK) GePrint("Error");
else if(cEngine->GetNumPairs() > 0){ count ++; GePrint(opc->GetName() + "Collision begin" + LongToString(cEngine->GetNumPairs())); collisions _= true; } else if(cEngine->GetNumPairs()== 0){ count ++; } } } } if(opc->GetDown()){ level++; opc = opc->GetDown(); }else if(opc->GetNext()){ opc = opc->GetNext(); }else if( level > 0){ opc = opc->GetUp()->GetNext(); level--; }else{ opc = opc->GetNext(); } }
Filling the ColliderChace I using this:
Bool FillColliderCache(GeColliderCache* c, BaseObject* obj) { // Get polygon object ModelingCommandData md1; md1.op = obj; md1.doc = obj->GetDocument(); if (!SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, md1)) return FALSE; // Triangulate it ModelingCommandData md2; md2.op = static_cast<BaseObject*>(md1.result->GetIndex(0)); if (!SendModelingCommand(MCOMMAND_TRIANGULATE, md2)) return FALSE; AutoAlloc<PolygonObject> poly(static_cast<PolygonObject*>(md2.op)); if (!poly) return FALSE; // Get the polygon data const CPolygon* tris = poly->GetPolygonR(); const Vector* points = poly->GetPointR();
//GeColliderCache* c = GeColliderCache::Alloc(); // Fill the cache if (c->BeginInput(poly->GetPolygonCount()) != COL_OK) return FALSE; for (int i = 0; i < poly->GetPolygonCount(); ++i) { if (c->AddTriangle(obj->GetMg() * points[tris _.a], obj- >GetMg() * points[tris _.b], obj- >GetMg() * points[tris _.c], i) != COL_OK) return FALSE; } if (c->EndInput() != COL_OK) return FALSE; //bool succ = c->CopyTo(dest);
poly.Free();
//GeColliderCache::Free(c);
return true;//succ; }
On 22/07/2011 at 16:20, xxxxxxxx wrote:
1. The object for GeCollider must be a polygon object.
2. Current-State-To-Object returns the cache result so your polygon object may be under a Null object:
Null -- Mesh
To avoid that situation, I call a method after doing the CSTO to find the polygon object that might be childed under something else.
{ ... if (!SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, mcd) && mcd.result) return NULL; // Get result PolygonObject* cstoObj = ToPoly(mcd.result->GetIndex(0L)); AtomArray::Free(mcd.result); if (!cstoObj) return NULL; return GetCSTOObject(cstoObj); } // Drill down into mainop and find the polygon object (if any) //*---------------------------------------------------------------------------* PolygonObject* CollisionDeformerObj::GetCSTOObject(BaseObject* op) //*---------------------------------------------------------------------------* { PolygonObject* pop = NULL; for (; op; op = op->GetNext()) { if (op->GetType() == Opolygon) return ToPoly(op); if (op->GetDown()) { pop = GetCSTOObject(op->GetDown()); if (pop) return pop; } } return NULL; }
