Select an inactive object
On 21/07/2011 at 21:30, xxxxxxxx wrote:
Cinema 4D Version: 12
Platform: Windows ;
Hello,How do I go about having my tool select an inactive object in the viewport.
I think this could be done by walking the hierarchy and getting every object in the scene and checking collisions with the mouse for each one but that seems quite costly on memory and cpu. Is there a function in the SDK that I am overlooking that will help me to select inactive objects in the viewport?
I know that I will use SetActiveObject() to set the object as active but I am not sure how I will get the object that is located behind the mouse?
Thanks,
Shawn
On 21/07/2011 at 22:19, xxxxxxxx wrote:
This is from my InterPoser Pro Tool Draw method. The mouseX and mouseY are stored in GetCursorInfo() for the tool.
// Mouse outside of Editor view if (mouseX < 0.0) return drawFlags; // Add IPP objects under cursor to selection list AutoAlloc<C4DObjectList> objList; if (!objList) return drawFlags; if (!SelectionListCreate(doc, NULL, bd, mouseX, mouseY, NULL, objList)) return drawFlags; LONG cnt = objList->GetCount(); if (!cnt) return drawFlags; // Set level of object to highlight LONG i = 0L; LONG a = 0L; // - lets us go back to level=0 if the level is beyond valid selections LONG seg = -1L; BaseTag* ippTag = NULL; BaseObject* obj = NULL; BaseContainer* bc = NULL; BaseContainer* fbc = NULL; // Skip objects in list that aren't conformant for (a = 0; a < cnt; ++a) { obj = objList->GetObject(a); // Only check IPP objects if (obj->IsInstanceOf(ID_IPPBASE)) { if (!(bc = obj->GetDataInstance())) continue; hilitedBP = obj; obj = bc->GetObjectLink(IPP_ROOT, doc); if (!obj) return drawFlags; } ippTag = obj->GetTag(ID_IPPFIGURETAG); if (!ippTag) { ippTag = obj->GetTag(ID_IPPOBJECTTAG); if (!ippTag) continue; } if (ippTag->IsInstanceOf(ID_IPPFIGURETAG) && skipConformers) { fbc = ippTag->GetDataInstance(); if (fbc && fbc->GetBool(IPPFIGURE_CONFORMED)) continue; } if (seg == -1L) seg = a; if (i == level) break; ++i; } // - Invalid IPP object if (!(ippTag && obj)) return drawFlags; if (a == cnt) { if (seg != -1L) { level = 0L; a = seg; } else return drawFlags; }
Basically, I am getting a list of objects under the cursor using a C4DObjectList instance and making determinations about the validity afterwards (probably not as important but included for thoroughness). So, you could take the nearest object (using C4DObjectList::GetZ() to determine 'nearest') and then SetActiveObject() based on that criteria.
On 21/07/2011 at 22:21, xxxxxxxx wrote:
Note that you don't have to do this in the Draw() method. You want to do this in the MouseInput() method. But you should still store the cursor coordinates in GetCursorInfo() to use there. :)
Also, don't forget to call EventAdd() after SetActiveObject()!
On 21/07/2011 at 22:23, xxxxxxxx wrote:
Perfect.. Thanks Robert. I wish I could email you a beer or something. You really ought to be paid for all the help you give. :)
Thanks again!
~Shawn
On 22/07/2011 at 12:12, xxxxxxxx wrote:
Hey Robert, so your method works great. I am able to select objects and use qualifiers to multi select or deselect. One more question. How would i deselect all if the user clicks an area where there is no object behind the cursor?
Thanks,
Shawn
On 22/07/2011 at 12:37, xxxxxxxx wrote:
Hey Shawn,
Try it with a RayCollision. ;)
On 22/07/2011 at 13:23, xxxxxxxx wrote:
I would check the C4DObjectList for (cnt == 0) or (!cnt) as I do and if this is the case on a mouse click then you call:
if (!cnt)
AutoAlloc<AtomArray> atomArray;
if (atomArray)
BaseObject* sobj = NULL;
doc->GetActiveObjects(*atomArray, FALSE);
LONG cnt = atomArray->GetCount();
for (LONG i = 0L; i != cnt; ++i)
static_cast<BaseObject*>(atomArray->GetIndex(i))->DelBit(BIT_ACTIVE);
EventAdd();
On 22/07/2011 at 13:57, xxxxxxxx wrote:
Hmmm..
Well I added what you mentioned and it still does nothing when I click off an object.. Here's my function.. This function is called directly from MouseInput() :)
//SELECT OBJECT //==============================================// Bool MyClass::SelectObject(BaseDraw *bd) { //Get the active document BaseDocument *doc = GetActiveDocument(); if(!doc) return FALSE; //Check to see if the cursor is in the editor window if(mouseX < 0.0) return FALSE; //Add all objects under the cursor to the Object List AutoAlloc<C4DObjectList> objList; if (!objList)return FALSE; if (!SelectionListCreate(doc, NULL, bd, mouseX, mouseY, NULL, objList)) return FALSE; LONG objectCount = objList->GetCount(); if (!objectCount) return FALSE; BaseObject *obj = NULL; if (!objectCount) { GePrint("NO OBJECT"); AutoAlloc<AtomArray> atomArray; if (atomArray) { BaseObject* sobj = NULL; doc->GetActiveObjects(*atomArray, FALSE); LONG cnt = atomArray->GetCount(); for (int i = 0; i != cnt; ++i) { static_cast<BaseObject*>(atomArray->GetIndex(i))->DelBit(BIT_ACTIVE); } EventAdd(); } } //Loop through objects for(int i = 0; i < objectCount; ++i) { obj = objList->GetObject(i); BaseContainer state; if (GetInputEvent(BFM_INPUT_KEYBOARD, state)) { LONG key = state.GetLong(BFM_INPUT_QUALIFIER); if(key & QCTRL) { doc->SetActiveObject(obj, SELECTION_SUB); EventAdd(EVENT_FORCEREDRAW); } else if(key & QSHIFT) { doc->SetActiveObject(obj, SELECTION_ADD); EventAdd(EVENT_FORCEREDRAW); } else { doc->SetActiveObject(obj, SELECTION_NEW); EventAdd(EVENT_FORCEREDRAW); } } } }
On 22/07/2011 at 13:59, xxxxxxxx wrote:
Interestingly... the GePrint() that I added never shows up which must mean that objectCount is never = 0.
On 22/07/2011 at 14:02, xxxxxxxx wrote:
DOH! That was stupid..
This line was the reason...
if(!objectCount) return FALSE;
LOL
Oye.. Tired eyes.
Thanks again Robert.
~Shawn
On 22/07/2011 at 16:10, xxxxxxxx wrote:
Get thee to bed. :)
On 22/07/2011 at 16:12, xxxxxxxx wrote:
And you can get rid of the "BaseObject* sobj = NULL;" since I made the DelBit() a one-liner into atomArray instead of getting the object and then calling DelBit().
On 22/07/2011 at 16:16, xxxxxxxx wrote:
Already done.. :) Thanks. I got tired of looking at the "Initialized but not referenced " warning HAHAHA
I'm about to call it a night. :) I've been at it for a while today. Lots of good progress though. Thanks a lot for your help.
~Shawn
