doc.GetHighest - Program-crash
On 13/07/2011 at 18:06, xxxxxxxx wrote:
While finding the active Stage-object I get a Problem with the "GetHighest"-commando.
It returns the correct Object, when the stage-object is active, but when its inactive, the program crashes.
My Code:import c4d print doc.GetHighest(c4d.Ostage,False).GetName()
On 13/07/2011 at 21:24, xxxxxxxx wrote:
perhaps try to add an if() statement to make sure there is an active object first?
something like:import c4d
from c4d import documents as docsdoc = docs.GetActiveDocument()
obj = doc.GetActiveObject()if obj != None:
On 14/07/2011 at 03:58, xxxxxxxx wrote:
The commando is not searching for the highest active object, it is searching for the highest object in hierarchy. The program crashes, when finding a stage object, doesn't visible in renderer.
On 14/07/2011 at 06:50, xxxxxxxx wrote:
I can confirm this on Windows XP 32 Bit, but the Method crashes Cinema in any way I use it.
On 14/07/2011 at 09:05, xxxxxxxx wrote:
My OS: Win 7 64 bit - Ultimate
On 14/07/2011 at 15:43, xxxxxxxx wrote:
Ok, so i tested out your code in a new scene on my mac pro and i got no crashing and the script worked.
On 14/07/2011 at 17:06, xxxxxxxx wrote:
thanks,
but when i set the stage to invisible, the program crashes, too :(
On 15/07/2011 at 03:13, xxxxxxxx wrote:
Hi, I can confirm this crash. This needs to be fixed.
On 15/07/2011 at 04:17, xxxxxxxx wrote:
maybe the code for the commando will become public? This would be nice for working with it :)
On 15/07/2011 at 10:03, xxxxxxxx wrote:
confirmed. once the stage object is made invisible, it crashes. definitely a bug.
On 15/07/2011 at 12:20, xxxxxxxx wrote:
You can do the iteration by hand like this:
import c4d from c4d import gui def SearchOM(op) : if not op: return if op.GetDown() : return op.GetDown() while not op.GetNext() and op.GetUp() : op = op.GetUp() return op.GetNext() def main() : obj = doc.GetFirstObject() while obj: objtype = obj.GetType() mode = obj.GetEditorMode() if objtype == c4d.Ostage and mode == c4d.MODE_UNDEF: #If the Stage tag has grey dots obj.SetBit(c4d.BIT_ACTIVE) #Select it in the OM break #We found the first one. So break out of the loop obj = SearchOM(obj) c4d.EventAdd() if __name__=='__main__': main()
The three modes for those little dots are: c4d.MODE_ON, c4d. MODE_OFF, c4d.MODE_UNDEF.
On 21/07/2011 at 04:11, xxxxxxxx wrote:
Thank you ScottA
