Insert 2 point spline
On 05/07/2011 at 00:03, xxxxxxxx wrote:
Anyone got the code to insert a basic spline with 2 points into a scene
Started to look up spline in the docs and its a tad daunting
tia
On 05/07/2011 at 04:45, xxxxxxxx wrote:
# written on mobile device, not tested yet
def main() :
# get the first 2 objects in the scene
o1 = doc.GetFirstObject()
o2 = o1.GetNext()
o1 = o1.GetAbsPos(); o2 = o2.GetAbsPos()
spl = c4d.BaseObject(c4d.Ospline)
spl.ResizeObject(2) # pointcount
spl.SetPoint(0, o1)
spl.SetPoint(1, o2)
spl.Message(c4d.MSG_POINTS_CHANGED) # tell the spline it's points did change
doc.InsertObject(spl)
Niklas
On 05/07/2011 at 05:07, xxxxxxxx wrote:
Hi Niklas
Many thanks - a great helper
This is the sort of example we need in the documentation
On 05/07/2011 at 08:40, xxxxxxxx wrote:
Here's an example using the spline class:
from c4d import gui
def main() :
  myspline = c4d.SplineObject(2,c4d.SPLINETYPE_BEZIER)  #Create a 2pt. Bezier spline in memory only
  p1 = myspline.GetSplinePoint(0)  #Assign the first point to a variable
  p2 = myspline.GetSplinePoint(1)  #Assign the second point to a variable
  myspline.SetPoint(0, c4d.Vector(-100,0,0)) #Place the first point here
  myspline.SetPoint(1, c4d.Vector(100,0,0))  #Place the second point here
  myspline.Message(c4d.MSG_UPDATE)  #Should do this any time an object's points are changed
  doc.InsertObject(myspline)  #Insert it into the Object Manager from memory
  c4d.EventAdd() #Update C4D about the changes
if __name__=='__main__':
From here.
You can use the SplineData, SplineHelper, SplineLengthData classes on it to manipulate the points, segments, tangents.
On 05/07/2011 at 09:11, xxxxxxxx wrote:
As oyu might have notices, I already have posted a solution. 😉
On 05/07/2011 at 10:15, xxxxxxxx wrote:
Yeah. But he was asking how to make a two point spline based on the documentation.
And you posted an example using a spline object with it's points in the same positions as two objects.
He won't learn how to use the docs from that.
So I just thought that I'd give him an example that is based closer to how it's done in the docs.
That way he can see how they work. And be able to use the other functions and classes.
On 05/07/2011 at 15:18, xxxxxxxx wrote:
Its ok guys, you both helped out tremendously!
On 05/07/2011 at 22:52, xxxxxxxx wrote:
Thanks for ALL the input.
Be it short, long, official or whatever. Its actually very useful to see there's more than one way tackle the problem.
