CallCommand() help
    On 27/06/2011 at 13:37, xxxxxxxx wrote:
    So this is likely some noob mistake, some fundamental that I am missing.  I can get CallCommand to work great from the console but I can't for the life of me make it work in a script.  I'm not sure what I'm doing wrong.  The relevant part of the code is towards the bottom.  Thanks for your time!
    from c4d import SplineObject
    from c4d import documents
    from c4d import BaseTag
    from c4d import BaseSelect
    def add_spline(number_points, spline_length) :
        '''Returns a linear spline of a specified length that starts at the origin and extends through the y-axis'''
        segment_length = spline_length / (number_points - 1)
        spline = c4d.SplineObject(int(number_points), c4d.SPLINETYPE_LINEAR)
        index = 0
        while index <= (int(number_points) - 1) :
            if index == 0:
                spline.SetPoint(index, c4d.Vector())
                index += 1
                point_pos = c4d.Vector(0, 0, int((segment_length * index)))
                spline.SetPoint(index, point_pos)
                index += 1
        return spline
    def main() :
        # function creates a linear spline
        spline = add_spline(10, 500)
        # create tags
        constraint_tag = c4d.BaseTag(1018074)                                       # 1018074 //Constraint
        dynamics_tag = c4d.BaseTag(1018068)                                         # 1018068 //Spline Dynamics
        # add dynamics tag to spline
        spline.InsertTag(dynamics_tag)
        # create null
        null = c4d.BaseObject(c4d.Onull)
        # insert null into anchor field for constraint tag
        constraint_tag[c4d.HAIR_CONSTRAINTS_TAG_ANCHOR_LINK] = null
        # add constraint tag to spline
        spline.InsertTag(constraint_tag)
        # select point 0 on spline (at position 0, 0, 0)
        all_points = spline.GetPointS()
        all_points.Select(0)
        # set the spline to be the active object
        doc.SetActiveObject(spline, 1)
        # get all tags attached to spline
        tags = spline.GetTags()
        # push the button HAIR_CONSTRAINTS_TAG_SET_ANCHOR
        c4d.CallButton(tags[0], 5000)                                               # 5000 //HAIR_CONSTRAINTS_TAG_SET_ANCHOR
        # Add the spline and null to the scene
        doc.InsertObject(spline)
        doc.InsertObject(null)
    On 27/06/2011 at 16:23, xxxxxxxx wrote:
    Not a noob mistake at all. It's a tricky one that can happen a lot. Especially in scripts.
    Sometimes the object's need to be in the scene(not in memory) and C4D updated before you can go any further.
    try it this way:
      index = 0
          if index == 0:
              index += 1
              index += 1
      return spline
    def main() :
      # create tags
      # create null
      #Before we attempt to execute any buttons. Let's first update C4D about all these changes we've made first
      c4d.DrawViews(c4d.DRAWFLAGS_ONLY_ACTIVE_VIEW|c4d.DRAWFLAGS_NO_THREAD|c4d.DRAWFLAGS_NO_REDUCTION|c4d.DRAWFLAGS_STATICBREAK) #Update cinema 4d
    On 27/06/2011 at 20:01, xxxxxxxx wrote:
    Beautiful, Scott! Thank you so much.  This was definitely one of those sticky problems that's been with me for the last 4 days.  Cool technique to learn too.  Should come in handy in the future.
