On 24/06/2011 at 01:03, xxxxxxxx wrote:
I want to export a meshsequence of an animation. If I set the documenttime to a specific frame e.g. frame 5 and export the document, then cinema always export the mesh of frame 0.
Here ars some code snippets:
minFrame = 0 maxFrame = 10 while minFrame <= maxFrame : doc.SetTime(c4d.BaseTime(minFrame, fps))
filepathSuffix = filepath + "_" + str(minFrame) + "." + suffix c4d.documents.SaveDocument(doc, filepathSuffix, c4d.SAVEDOCUMENTFLAGS_0, format)
minFrame = minFrame + 1
How can I export the mesh of the frame, the playhead is?
On 24/06/2011 at 06:18, xxxxxxxx wrote:
In that code you set the time to frame 0, so it's starting there. Set it to start at current frame and set a useful last frame as well, like doc maxtime or loop maxtime.
Cheers Lennart
On 24/06/2011 at 06:58, xxxxxxxx wrote:
In the while-loop I increment the variable "minFrame".
If I set the minTime and maxTime of the document, cinema exports in every loopcycle the mesh of frame 0
Here is my code:
while minFrame <= maxFrame :; doc.SetMinTime(c4d.BaseTime(minFrame, fps)) doc.SetMaxTime(c4d.BaseTime(minFrame + 1, fps)) doc.SetTime(c4d.BaseTime(minFrame, fps))
On 24/06/2011 at 07:22, xxxxxxxx wrote:
In Py docs look for "Document Caching" , last in c4d.documents.BaseDocument section. There's a set up for running the scene, just add your save part in it.
On 27/06/2011 at 01:41, xxxxxxxx wrote:
Hi Lennard,
thank you for youre post.
I insert the GeSyncMessage methode to my code, but it has no impact on the results. Cinema exports the mesh of frame 0 to all of the exported files.
Here is the code:
fps = float(doc.GetFps())
minTime = doc.GetMinTime() minFrame = int(minTime.Get() * fps)
maxTime = doc.GetMaxTime() maxFrame = int(maxTime.Get() * fps)
doc.SetTime(minTime)
while minFrame <= maxFrame : c4d.StatusSetBar(100 / maxFrame * minFrame) doc.SetTime(c4d.BaseTime(minFrame, fps)) c4d.GeSyncMessage(c4d.EVMSG_TIMECHANGED)
minFrame = minFrame + 1 c4d.StatusClear() c4d.EventAdd(c4d.EVENT_ANIMATE)
On 27/06/2011 at 08:18, xxxxxxxx wrote:
Marcel, do look at the "Document Cache" example closer and you'll see that you need the DrawViews for anything to happen.
I do recommend using it as is as it works as expected. Add your save part in it where stated and you're all set.
On 27/06/2011 at 08:50, xxxxxxxx wrote:
You can see the parts put into it here, saving the selected object to a c4d file series. Look up the different functions in Py docs to see what they do. The .zfill() function is from http://docs.python.org
# Save Selected Object To FileSeries import c4d from c4d import documents, storage def BrowseDoc(doc,tofile) : """ Pass the document you want to run the time through""" ctime = doc.GetTime() #save current time fps = doc.GetFps() start = doc.GetMinTime().GetFrame(fps) #set min time until = doc.GetMaxTime().GetFrame(fps) for f in xrange(start, until) : c4d.StatusSetBar(100*(f-start)/(until-start)) doc.SetTime(c4d.BaseTime(f, fps)) c4d.DrawViews(c4d.DRAWFLAGS_ONLY_ACTIVE_VIEW|c4d.DRAWFLAGS_NO_THREAD|c4d.DRAWFLAGS_NO_REDUCTION|c4d.DRAWFLAGS_STATICBREAK) # do your caching here. 'f' is the current frame objdoc = documents.IsolateObjects(doc,[doc.GetActiveObject()]) tofile = tofile+'_'+str(f).zfill(5)+'.c4d' c4d.documents.SaveDocument(objdoc,tofile,c4d.SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST,c4d.FORMAT_C4DEXPORT) c4d.GeSyncMessage(c4d.EVMSG_TIMECHANGED) #update timeline doc.SetTime(ctime) #set time back c4d.EventAdd(c4d.EVENT_ANIMATE) c4d.StatusClear() def main() : if doc.GetActiveObject() is None:# Single Object not selected return False tofile = c4d.storage.SaveDialog(c4d.FILESELECTTYPE_ANYTHING) if tofile: BrowseDoc(doc,tofile) if __name__=='__main__': main()
On 29/06/2011 at 00:28, xxxxxxxx wrote:
Hi Lennart,
it works. Thank you so much.
