SplineHelp PrimSplines Segment Error
    On 23/06/2011 at 06:46, xxxxxxxx wrote:
    Let me know what I could miss here.
    Using SplineHelp() on a Primitive splineobject
    (like Text) only segment 0 is possible.
    Calling segment > 0 gets out of range.
    Also, still calling segment 0, going to position 1.0 (100%) the position
    jumps to next segments first position
    Regular splines (Pointobjects with several segments) work as expected.
    def main() :
        segment = 0 # <- If spline is a Prim only segment 0 works
        posUD = op[c4d.ID_USERDATA,1] # Userdata entry
        spline = op[c4d.ID_USERDATA,2] # Userdata linkfield
        if spline is None or spline.GetRealSpline() is None:
            #print 'No Spline'
            return False
        shspline = SplineHelp()
        rs       = spline.GetRealSpline()
        # try using rs in SplineHelp.InitSpline and "use_deformed_points" fail
        # but segments >0 works
        shspline.InitSpline(spline,c4d.Vector(0.0),None, False,True, False,True)
        pos      = shspline.GetPos(posUD , segment , True)
        shspline.FreeSpline()
        obj = op.GetObject()
        objm = obj.GetMg()
        objm.off = pos
        obj.SetMg(objm)
    Lennart
    On 25/06/2011 at 03:12, xxxxxxxx wrote:
    I can confirm that. The segment exception shouldnt be raised.
    On 25/06/2011 at 06:47, xxxxxxxx wrote:
    Thanks Sebastian for checking and on a week end no less!
    Please let us know when / if it is fixed (If possible).
    May I ask, regarding SplineHelp() vs SplineLengthData()..
    Why do we "need" both? They are a bit "same same but different".
    Is one of them to prefere when using splines?
    Lennart
