On 17/06/2011 at 09:42, xxxxxxxx wrote:
And this one is a good one. I hate restarting cinema 4d because i want to test my async dialog but i can only open it in a command data >.>
from c4d.gui import GeDialog from threading import Thread class DialogThread(Thread) : """ A class to enable opening ASync Dialogs in the Skript Manager. Initialise with a GeDialog subclass instance. """ class ArgumentError(Exception) : """ Raised when a bad argument is given. """ def __init__(self, dlg) : # initialise with a GeDialog subclass instance if not issubclass(dlg.__class__, GeDialog) : raise self.ArgumentError, "Overloaded argument 'dlg' is not an instance of GeDialog or an instance of a subclass of GeDialog.\n" \ \+ "It is an instance of: %s" % dlg.__class__.__name__ Thread.__init__(self) self.dlg = dlg def run(self) : # wait until the dialog is closed while self.dlg.IsOpen() : pass def start(self, opentype = c4d.DLG_TYPE_ASYNC) : # open the dialog and start Superclass' start(). self.dlg.Open(opentype) Thread.start(self) def OpenAsyncDialog(dlg) : dlg_thread = DialogThread(dlg) dlg_thread.start() return dlg_thread
Maybe at least this can be added to the Py4D Standart Library ? Would be pretty useful for skripts, hehe.
//edit: Hm, again some issues. is there any way to keep the globals within a Thread ? >.>
