create a beveled cube
On 16/06/2011 at 18:08, xxxxxxxx wrote:
ok, so i have tried a number of different things but i still cant get the SendModellingCommand to work. I have simplified my idea drastically to try and get the basic idea working, but i still am not doing something right. Essentially, all i want to do right now, is create a beveled cube using a python object. here is my scene file. i got it to stop crashing, but it will not bevel.
any help is greatly appreciated.here is a link to download the c4d file
http://www.sendspace.com/file/zsg754and here is the code within the python generator:
#Welcome to helldef main() :
doc = c4d.documents.GetActiveDocument
cube = c4d.BaseObject(c4d.Ocube)
null = c4d.BaseObject(c4d.Onull)
cube1 = MakeEditable(cube)
cube2 = Bevel(cube1,30)
return cube2def ExtrudeInner(obj,offset,doc) :
passdef Bevel(op,offset) :
bc = c4d.BaseContainer()
bc[2042] = offset
if(not op) | op.CheckType(c4d.Opolygon) | op.CheckType(c4d.Ospline) : return op
doc = c4d.documents.BaseDocument()
doc.InsertObject(op[1], None, None)
obj = c4d.utils.SendModelingCommand(
command = 450000005,#bevel
list = obj,
settings = bc,
doc = doc )
return obj[1]def MakeEditable(op) :
if (not op) | op.CheckType(c4d.Opolygon) | op.CheckType(c4d.Ospline) : return opop = [op.GetClone()]
doc.InsertObject(op[0],None,None)
op = c4d.utils.SendModelingCommand(
command = c4d.MCOMMAND_MAKEEDITABLE,
list = op,
mode = c4d.MODELINGCOMMANDMODE_EDGESELECTION,
doc = doc )
return op[0]
On 17/06/2011 at 03:00, xxxxxxxx wrote:
First of all, use ID's instead of Integers
instead of "2042" use "c4d.MDATA_BEVEL_OFFSET2"
But with "450000005" you seem to be right, there doesnt seem to be a id in the c4d module. O.oSecond: hehe my MakeEditable Function ;p
Third: Do you think about what you are doing when you modify a Function ? ^^bc[2042] = offset if(not op) | op.CheckType(c4d.Opolygon) | op.CheckType(c4d.Ospline) : return op doc = c4d.documents.BaseDocument()
The middle line doesn't make sense. It MUST be Polygon object to be beveled, not the other way round.
obj = c4d.utils.SendModelingCommand( command = 450000005,#bevel list = obj,
Where the heck does that obj - variable come from ?
but you have never seen an exception because of this variable bacuase the function was ended before this part of the code was evaluated. (See above)doc.InsertObject(op[1], None, None)
why do you use __getitem__ here, and why with 1 ?!
op IS a baseObject in your case, not a list.settings = bc,
"settings" is an unknow keyword for SendModelingCommand. The right keyword is called "bc".
obj = c4d.utils.SendModelingCommand( command = 450000005,#bevel list = [op], bc = bc, doc = doc ) return obj[1]
If you would have read the SendModelingCommand documentation, you would have known that the return type of this Functions depends on its arguments.
In this case, they Modelingcommand is processed on the original object. The returnvalue is boolean value indicating wether the Execution was successful or not.The correct code is as follows:
import c4d #Welcome to the world of Python def ExtrudeInner(obj,offset,doc) : pass def Bevel(op,offset) : bc = c4d.BaseContainer() bc[c4d.MDATA_BEVEL_OFFSET2] = offset bc[c4d.MDATA_BEVEL_MODE] = c4d.MDATA_BEVEL_MODE_LINEAR if (not op) | (not op.CheckType(c4d.Opolygon)) : return op doc = c4d.documents.BaseDocument() doc.InsertObject(op, None, None) print c4d.utils.SendModelingCommand( command = 450000005,#bevel list = [op], bc = bc, doc = doc, mode = c4d.MODIFY_EDGESELECTION ) return op.GetClone() def MakeEditable(op) : if (not op) | op.CheckType(c4d.Opolygon) | op.CheckType(c4d.Ospline) : return op op = [op.GetClone()] doc = c4d.documents.BaseDocument() doc.InsertObject(op[0],None,None) op = c4d.utils.SendModelingCommand( command = c4d.MCOMMAND_MAKEEDITABLE, list = op, mode = c4d.MODELINGCOMMANDMODE_EDGESELECTION, doc = doc ) return op[0] def main() : doc = c4d.documents.GetActiveDocument cube = c4d.BaseObject(c4d.Ocube) null = c4d.BaseObject(c4d.Onull) cube1 = MakeEditable(cube) cube2 = Bevel(cube1,10) return cube2
On 18/06/2011 at 21:23, xxxxxxxx wrote:
Wow, nux, all I can say is thank you. That was one of the most helpful posts I have ever recieved. not only did you fix the code but u helped me to understand where I was going wrong. Thank u so much dude. U rule.
