Size of Polygonselektion
On 14/06/2011 at 08:18, xxxxxxxx wrote:
Cinema 4D Version:   12
Platform:      Mac OSX  ;
Hello Folks,
I wrote a script to get the Size of a Pointselection. Now I want to do the Same thing for a Polyselection. I am stucked here. I hope someone can help me.
Here is my approach to get x,y,z-dimensions of a Pointselection.
var doc = GetActiveDocument();
var obj = doc -> GetActiveObject();
doc->StartUndo();
doc->AddUndo(UNDO_OBJECT_BASEDATA, obj);
var select = obj -> GetPointSelection();
var i;
var found = 0;
var sum = 0;
var minX=100000000, minY=100000000, minZ=1000000000;
var maxX=0, maxY=0, maxZ=0;
for (i = 0; i < obj -> GetPointCount(); i++){
 if (found >= select -> GetCount()) break;
 if (select -> IsSelected(i)){
 var temp = obj->GetPoint(i);
if (temp.x>maxX)  maxX=temp.x;
if (temp.x<=minX)  minX=temp.x;
if (temp.y>maxY)  maxY=temp.y;
if (temp.y<=minY)  minY=temp.y;
if (temp.z>maxZ)  maxZ=temp.z;
if (temp.z<=minZ)  minZ=temp.z;
	found++;
var sizeX=maxX-minX;
var sizeY=maxY-minY;
var sizeZ=maxZ-minZ;
println("Size x:", sizeX);
println("Size y:", sizeY);
println("Size Z:", sizeZ);
found = 0;
On 16/06/2011 at 06:32, xxxxxxxx wrote:
Basically you do the same as for point selections. You iterate through the selected polygons and use the point indices to obtain the point positions. Then you check for minima/maxima the same as for point selections.
cheers,
Matthias
On 17/06/2011 at 01:03, xxxxxxxx wrote:
Thanks for the respond. I got it work now.
cheers, Holger
