On 09/06/2011 at 07:14, xxxxxxxx wrote:
Header File parser for Py4D - BETA - - - - - - - - - - - - - -
I was sick including the ID's for a dialog created in ResEdit myself into Python. Therefore I wrote a Header File parser. It will only analyze an enum statement.
First, download the package below and copy the folder to your Py4D library. In your plugin, use this code to parse the c4d_symbols.h and insert the ID's into the global scope.
from HeaderFileParser import parse from os.path import join, abspath, dirname parse( join( dirname( abspath(__file__)), "res", "c4d_symbols.h", ), globals(), )
You can now use the ID's defined in c4d_symbols.h in you Plugin.
Remember, this is still BETA. If any problems occure, please report it ! As this is still BETA, you might only use this while you are still developing your plugin and your GUI might change.
HeaderFileParser_BETA_0.9
Cheers, Niklas
//Link fixed
EDIT: The c4dtools library now does this for you!
On 25/08/2011 at 11:30, xxxxxxxx wrote:
I'd suggest the following use:
class foo: 'Just to store data' res = foo() from HeaderFileParser import parse parse(path_to_c4d_symbols_h, res.__dict__)
This will copy all ID's as attributes to the foo-instance and you can use them like this:
res.MY_ID
To replace the HeaderFileParser (for example to release the plugin and to be independent from it), you can print the dictionary that contains the IDs and copy the output into your plugin like this:
print res.__dict__
... Copy the output to clipboard, comment out the code from the HeaderFileParser and do
class foo: 'Just to store data' res = foo() # # # # # # # # # # # # # # # # # # # # # # # # # # from HeaderFileParser import parse # # parse(path_to_c4d_symbols_h, res.__dict__) # # # # # # # # # # # # # # # # # # # # # # # # res.__dict__ = {'MY_ID': 10023, ...} # the output pasted from the clipboard
