On 03/06/2011 at 12:32, xxxxxxxx wrote:
Is it correct that even if I don't want to make res for entries (faders and such in AM) a PyTag must have all the description/res files (.h , .str etc..)?
As it is right now I will only use Userdata on my tags. When I try to delete them I get error at start up.
All my res files are blanket and it works when they are there even if they don't add anything! (Except the icon of coarse)
Cheers Lennart
On 03/06/2011 at 12:39, xxxxxxxx wrote:
Yes, unfortunatelay, they do need a ressourcefile. The res-files shouldn't be blanket. Just create a dummy ressource.
PS: Or do you want to test DescEdit ? PS2: I can't send you a private message. It tells me your username is not found in the system.
On 03/06/2011 at 13:23, xxxxxxxx wrote:
Thanks nux. What can DescEdit do?
Yes, my username got crumpled a while ago when this site was updated, I don't know what it is myself! It looks something like t&#a:))/udiÖs !! <br /> <br />But I'm at: tcastudios at me dot com
On 03/06/2011 at 14:36, xxxxxxxx wrote:
It can already create fully working Descriptions with User Interface !
Can you join to the IRC right now ? Would be better to talk there.
loooool. Thanks
