On 27/05/2011 at 12:09, xxxxxxxx wrote:
Because of the missing GUI ID's used for GeDialog.AddCustomGui(), here's a module providing all of them. They were copied from ResEdit. If you find an issue, please report it. Place the folder in your Cinema 4D Userfolder under "library\python\packages%osbuild%". On Windows this would be: "C:\Users%USER%\AppData\Roaming\MAXON%CINEAM4D%\library\python\packages%osbuild%".
Or use my ImportPatch Plugin.
After doing so, you can import those ID's using
import gui_elements for i in dir(gui_elements) : print (str(i)+":").ljust(20) + str(gui_elements.__dict__[i])
Download gui_elements
Cheers, Niklas
