HPBToMatrix(hpb,order error)
On 26/05/2011 at 05:03, xxxxxxxx wrote:
Hi.
Going thru Matrix utils options I need to check if this is correct.Using HPBToMatrix(hpb,order),
When putting the numeric options ("ROT_YXZGLOBAL" etc)
as order, I get "not defined" (I have utils imported)I can put any integer there (even higher than the 12 options)
and to me it make no difference?Also in SDK it say order is vector but as above it should be integer,right?
Lennart
On 01/06/2011 at 09:16, xxxxxxxx wrote:
Please check this out:
from c4d import utils
utils.HPBToMatrix(c4d.Vector(1,2,3),c4d.ROT_YXZGLOBAL)
On 03/06/2011 at 08:58, xxxxxxxx wrote:
Tops Sebastian, will try it out asap.
Lennart
