Creating Attribute manager controls
    On 25/05/2011 at 16:49, xxxxxxxx wrote:
    LOL. Whatever it takes.
    You don't want to know what goes through my head in order for me to use pointers in C++ 😉
    The main reason I was curious about it is because your code doesn't work when I try to use it on something other than a button. Like say a checkbox for example.
    I thought that maybe the "if type<>18: " meant "if the type is a button".
    So I was curious if there were other numbers that would allow things like checkboxes to work in a similar manner.
    I guess I'll have to try them out too. And see if anything happens.
    Thanks for the information.
    On 25/05/2011 at 21:58, xxxxxxxx wrote:
    Your ID is not wokring because of the missing prefix. ;)
    c4d.CLICK_ME
    On 26/05/2011 at 02:20, xxxxxxxx wrote:
    With this simple example of what happened to me I realized once more that the documentation for python in Cinema4D is still very sparcely arranged, lacking a lot of stuff and not very clean in general :-(
    One has to do lots of questions, lots of digging in and a whole lot of trial&error; attempts to get even the simplest results :-(
    Rui Batista
    On 26/05/2011 at 05:30, xxxxxxxx wrote:
    I donÄt understand what you want to do with type != 18.. ?!
    The GetMessageID function works fine for me. It returns the pressed GUI Element's ID, i.e. a button's id.
    On 26/05/2011 at 07:21, xxxxxxxx wrote:
    c4d.CLICK_ME
    Son of a @#@$#@$#@#@!!!.
    I swear to God. That frakin' c4d. prefix is out to get me. 😂
    I thought I had finally squashed that prefix demon...Guess not.
    Instead of going round and round. And telling us it works for you in two threads nux.
    Why not take that plugin example I posted. And add the button code to it and show us?
    You have my permission to do that.
    On 26/05/2011 at 08:13, xxxxxxxx wrote:
    And where is the GetMessageID information?
    I typed it in the search field of the python documentation and nothing appeared :-(
    On 26/05/2011 at 10:52, xxxxxxxx wrote:
    @Rui:
    The function is self-made. ;)
    Hm I could now look it up and i used this:
    def GetMessageID(data) :
      try:
          return data["id"][0].id
      except:
          return None
    cheers
    @Scott:
    So it's still not working for you ? (my english is too bad -.-)
    I will tomorrow post you an absolutely fully working example !
    Yes. Using the .c4d prefix works. 👍
    I was just yelling at myself for making such a stupid mistake. That I thought I had stopped myself from making anymore.
    Please do post a working example with your button code in it.
    Feel free to use the plugin I posted.  Or one of your own if you prefer.
    Whatever is easier.
    On 26/05/2011 at 14:36, xxxxxxxx wrote:
    I changed my plug-in tag to use the GetMessageID(data) function and the id names.
    I guess that the type check for 18 allow the procedure to terminate sooner if no button is being pressed but I also removed that check.
    It is working just fine, now :-)
    Thank you all, once again.
    Rui Batista
    On 27/05/2011 at 07:10, xxxxxxxx wrote:
    So, here it is. A fully working example of a TagData Plugin demonstrating the use of descriptions.
    http://www.file-upload.net/download-3462169/PyTag-Example.rar.html
    Niklas
