Adding to a Layer Object
    On 22/05/2011 at 18:24, xxxxxxxx wrote:
    Cinema 4D Version:   12
    Platform:   Windows  ; Mac  ;
    I am able to add a layer to the layer browser through the following code:
     LayerObject *layer = NULL;
       layer = LayerObject::Alloc();
       if (!layer) return FALSE;
       GeListHead *layerlist = NULL;
       layerlist = doc->GetLayerObjectRoot();
       if (!layerlist) return FALSE;
      layer->SetName("My TEST Layer");
       layerlist->Insert(layer, NULL, NULL);
       layerlist->Message(MSG_UPDATE);
    Now I would like to add various objects from my plugin to that layer.  I tried doing
    myObject->SetLayerObject(layer);
    but it doesn't seem to work.
    Any ideas on how to do this?
    Thanks,
    ~Shawn
    On 23/05/2011 at 02:44, xxxxxxxx wrote:
    Not sure what's going wrong there. Here it's working.
    My code:
    Bool MenuTest::Execute(BaseDocument *doc)
      BaseObject *op = NULL;
      op = doc->GetActiveObject();
      if (!op) return FALSE;
      layer->Message(MSG_UPDATE);
      if (!op->SetLayerObject(layer)) return FALSE;
      op->Message(MSG_UPDATE);
      EventAdd();
      return TRUE;
    cheers,
    Matthias
    On 23/05/2011 at 03:08, xxxxxxxx wrote:
    Well the only difference between my code and yours is that my LayerObject is a member variable and is initialized in Init() then the call to add an object to that l layer is in a different function...
    Do you think think that this is the reason it is not working?
    Thanks,
    Shawn
    On 23/05/2011 at 03:15, xxxxxxxx wrote:
    As long as you make sure the layer object is valid and inserted into the layer list there shouldn't be a problem.
    cheers,
    Matthias
    On 23/05/2011 at 03:20, xxxxxxxx wrote:
    Okay I will tinker some more with it ..  Thanks Matthias.
    ~Shawn
