On 17/05/2011 at 15:48, xxxxxxxx wrote:
User Information: Cinema 4D Version: R12 Platform: Language(s) : C++ ;
--------- Hi All,
here my first question: How to split a PolgonObject with multiple PolygonSelection-Tags (for Materials) into multiple PolygonObjects?
Here my start.
void Walk(BaseObject *object) { while (object) { if(object->GetType() == Tpolygon) { BaseTag *tag = object->GetFirstTag(); while (tag) { if (tag->GetType() == Tpolygonselection) { SelectionTag *selectionTag = (SelectionTag * )tag; BaseSelect *select = selectionTag->GetBaseSelect(); /*... alloc new PolygonObjects, fill given data */ } tag = tag->GetNext(); } if (object->GetDown()) { //recursive walk Walk(op->GetDown()); } object = object->GetNext(); } } }
Thanks, ToBSn
On 17/05/2011 at 17:00, xxxxxxxx wrote:
Select the polygons of the PolygonSelection and then use SendModelingCommand() to do a split. Here is a convenience method which does it for you:
PolygonObject* SplitObject(PolygonObject* op, SelectionTag* pstag) { // BaseSelect of Polygon Selection Tag BaseSelect* pbs = pstag->GetBaseSelect(); if (!pbs) return NULL; // BaseSelect of Polygon Object BaseSelect* bs = op->GetPolygonS(); if (!bs) return NULL; // Select Polygons on Polygon Object belonging to Polygon Selection Tag if (!pbs->CopyTo(bs)) return NULL; // Split selected polygons (tops) into new object ModelingCommandData mcd; mcd.doc = NULL; mcd.bc = NULL; mcd.mode = MODELINGCOMMANDMODE_POLYGONSELECTION; mcd.flags = MODELINGCOMMANDFLAGS_0; mcd.op = op; if (!(SendModelingCommand(MCOMMAND_SPLIT, mcd) && mcd.result)) return NULL; PolygonObject* top = ToPoly(mcd.result->GetIndex(0L)); // - it is your responsibility to free the 'result' AtomArray returned in 'mcd'! AtomArray::Free(mcd.result); return top; }
On 18/05/2011 at 01:14, xxxxxxxx wrote:
Just btw: If a non-polygonobject is parsed, you will never ever leave the while-loop.
On 18/05/2011 at 01:34, xxxxxxxx wrote:
@kuroyume0161 Very cool, thank you. Clever idea to use the modeling command.
@nux95 a yeah, thats right. thanks.
On 18/05/2011 at 08:21, xxxxxxxx wrote:
To avoid the infinite while-loop just move the line "object = object->GetNext();" outside of the if() block.
SendModelingCommand() is your friend ... most of the time but depending upon its mood.
