On 17/05/2011 at 14:05, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11.5&12 Platform: Mac ; Mac OSX ; Language(s) : C.O.F.F.E.E ;
--------- Hi all !
One of my C.O.F.F.E.E plugins doesn't works only on R12.043 on OSX. It has been checked on windows 11.5 & 12 / x86 & x64. It also works well on older than R12 versions on Mac.
I wonder how a C.O.F.F.E.E based plugin can be non-working only on R12.043 on mac.
Console reports :
"COFFEE ERROR! (124) Syntax error File: EasyArea.cob Line: 1 Row: ~1"
As it blocks on the 1st char could it be a compilation reading problem on R12 on mac ? I used the 9.5 SDK's C.O.F.F.E.E compiler.
I tried changing the 1st row and it leads to the same error.
Tomorrow I'll try directly with .COF file instead of .COB.
Thanks
M!ke
On 18/05/2011 at 01:00, xxxxxxxx wrote:
I had the same issue sometimes. Ah damn, I just can't remember how I could solve the problem ~.~ I will tell you as soon as I remember it !!
On 18/05/2011 at 01:02, xxxxxxxx wrote:
It's not a compilation error, If it's the exactly same problem as I had. But I had this problem on Windows. hm..
On 20/05/2011 at 13:07, xxxxxxxx wrote:
I got it !
The problem came from the fact that I refered to a vrayobject ID.
2 weird things :
1 - The error was detected at line 1 row 1, although the wrong line was far away from that.
2 - The line was :
if (op->GetType() == XXXXX) { do sth; }
Where XXXXX refers to the ID of a VrayForC4D Object. I taught that this line would return false if the object wasn't known, instead of this it returned an error :s.
Mike
On 20/05/2011 at 14:14, xxxxxxxx wrote:
Are you using the number or the enumation name? If you use the latter, define the name and associate it with the number. Then it won't error if VrayForC4D isn't installed.
