On 16/05/2011 at 18:01, xxxxxxxx wrote:
User Information: Cinema 4D Version: 12 Platform: Windows ; Mac ; Language(s) : C++ ;
--------- I have written functions that save presets and load presets for my object plugin. The functions use a BaseFile and loads and saves parameters.
Here is the LoadPresets() function..
//LOAD PRESET //====================================================// Bool PXGPlanet::LoadPreset(GeListNode* node, Filename file){ BaseObject *op = (BaseObject* )node; BaseContainer *bc = op->GetDataInstance(); //Declare the BaseFile AutoAlloc<BaseFile> bf; //Open the BaseFile for Reading. #ifdef C4D_R12 bf->Open(file, FILEOPEN_READ, FILEDIALOG_IGNOREOPEN, BYTEORDER_INTEL, MACTYPE_CINEMA, MACCREATOR_CINEMA); #else bf->Open(file, GE_READ, FILE_IGNOREOPEN, GE_INTEL, MACTYPE_CINEMA, MACCREATOR_CINEMA); #endif //Read PXG Attributes from the File. //GENERAL //==========================================================// //Planet Shape LONG pshape; bf->ReadLong(&pshape); bc->SetLong(PLANETX_GENERAL_SHAPE, pshape); //Radius LReal genrad; bf->ReadLReal(&genrad); bc->SetReal(PLANETX_GENERAL_RADIUS, genrad); //Segments LReal genseg; bf->ReadLReal(&genseg); bc->SetReal(PLANETX_GENERAL_SEGMENTS, genseg); //Height LReal genht; bf->ReadLReal(&genht); bc->SetReal(PLANETX_GENERAL_HEIGHT, genht); //Enable Rotation Bool enrot; bf->ReadBool(&enrot); bc->SetBool(PLANETX_GENERAL_ENABLE_ROTATION, enrot); //Rotation Direction LONG rotdir; bf->ReadLong(&rotdir); bc->SetLong(PLANETX_GENERAL_ROTATION_DIRECTION, rotdir); //Rotation Speed LReal rotspeed; bf->ReadLReal(&rotspeed); bc->SetReal(PLANETX_GENERAL_ROTATION_SPEED, rotspeed); //Frame Rate FPS LReal framerate; bf->ReadLReal(&framerate); bc->SetReal(PLANETX_GENERAL_SCENEFPS, framerate); //SURFACE //==========================================================// //Surface Map Filename smap; bf->ReadFilename(&smap); bc->SetFilename(PLANETX_SURFACE_SURFACE_MAP, smap); //Enable Specular Bool enspec; bf->ReadBool(&enspec); bc->SetBool(PLANETX_SURFACE_SPEC_ENABLE, enspec); //Specular Mode LONG specmode; bf->ReadLong(&specmode); bc->SetLong(PLANETX_SURFACE_SPEC_MODE, specmode); //Specular Width LReal specwidth; bf->ReadLReal(&specwidth); bc->SetReal(PLANETX_SURFACE_SPEC_WIDTH, specwidth); //Specular Height LReal specheight; bf->ReadLReal(&specheight); bc->SetReal(PLANETX_SURFACE_SPEC_HEIGHT, specheight); //Specular Falloff LReal specfalloff; bf->ReadLReal(&specfalloff); bc->SetReal(PLANETX_SURFACE_SPEC_FALLOFF, specfalloff); //Specular Inner Width LReal speciwidth; bf->ReadLReal(&speciwidth); bc->SetReal(PLANETX_SURFACE_SPEC_INNER_WIDTH, speciwidth); //Enable Generator Bool engen; bf->ReadBool(&engen); bc->SetBool(PLANETX_SURFACE_ENABLE_GENERATOR, engen); //Sea Color LVector seacolor; bf->ReadLVector(&seacolor); #ifdef C4D_R12 bc->SetVector(PLANETX_SURFACE_SEA_COLOR, seacolor); #else bc->SetVector(PLANETX_SURFACE_SEA_COLOR, Vector(seacolor.x, seacolor.y, seacolor.z)); #endif //Land Color LVector landcolor; bf->ReadLVector(&landcolor); #ifdef C4D_R12 bc->SetVector(PLANETX_SURFACE_LAND_COLOR, landcolor); #else bc->SetVector(PLANETX_SURFACE_LAND_COLOR, Vector(landcolor.x, landcolor.y, landcolor.z)); #endif //Mountain Color LVector mtncolor; bf->ReadLVector(&mtncolor); #ifdef C4D_R12 bc->SetVector(PLANETX_SURFACE_MOUNTAIN_COLOR, mtncolor); #else bc->SetVector(PLANETX_SURFACE_MOUNTAIN_COLOR, Vector(mtncolor.x, mtncolor.y, mtncolor.z)); #endif //Level LReal level; bf->ReadLReal(&level); bc->SetReal(PLANETX_SURFACE_LEVEL, level); //Frequnecy LReal freq; bf->ReadLReal(&freq); bc->SetReal(PLANETX_SURFACE_FREQUENCY, freq); //Generator Reflection Bool genref; bf->ReadBool(&genref); bc->SetBool(PLANETX_SURFACE_GENERATOR_USE_REFLECTION, genref); //Generator Elevation Bool genelev; bf->ReadBool(&genelev); bc->SetBool(PLANETX_SURFACE_GENERATOR_USE_ELEVATION, genelev); //Reflection Strength LReal refstr; bf->ReadLReal(&refstr); bc->SetReal(PLANETX_SURFACE_SURFACE_REFLECTION_GEN, refstr); //Elevation Strength LReal elvstr; bf->ReadLReal(&elvstr); bc->SetReal(PLANETX_SURFACE_ELEVATION_STRENGTH_GEN, elvstr); //Use Reflection Map Bool usermap; bf->ReadBool(&usermap); bc->SetBool(PLANETX_SURFACE_REFLECTION_USE_MAP, usermap); //Reflection Map Filename rmap; bf->ReadFilename(&rmap); bc->SetFilename(PLANETX_SURFACE_REFLECTION_MAP, rmap); //Reflection Mix LReal refmix; bf->ReadLReal(&refmix); bc->SetReal(PLANETX_SURFACE_SURFACE_REFLECTION_MMIX, refmix); //Surface Reflection LReal surfref; bf->ReadLReal(&surfref); bc->SetReal(PLANETX_SURFACE_SURFACE_REFLECTION,surfref); //Elevation Map Filename emap; bf->ReadFilename(&emap); bc->SetFilename(PLANETX_SURFACE_ELEVATION_MAP, emap); //Elevation Strength LReal estrength; bf->ReadLReal(&estrength); bc->SetReal(PLANETX_SURFACE_ELEVATION_STRENGTH, estrength); //Use Normal Map Bool useemap; bf->ReadBool(&useemap); bc->SetBool(PLANETX_SURFACE_USE_NORMAL_MAP, useemap); //Normal Map Filename nmap; bf->ReadFilename(&nmap); bc->SetFilename(PLANETX_SURFACE_NORMAL_MAP,nmap); //Normal Strength LReal nstrength; bf->ReadLReal(&nstrength); bc->SetReal(PLANETX_SURFACE_NORMAL_STRENGTH, nstrength); //CLOUDS //==========================================================// //Enable Clouds Bool enclouds; bf->ReadBool(&enclouds); bc->SetBool(PLANETX_CLOUDS_ENABLE, enclouds); //Cloud Map Filename cmap; bf->ReadFilename(&cmap); bc->SetFilename(PLANETX_CLOUD_CLOUD_MAP,cmap); //Cloud Color LVector ccolor; bf->ReadLVector(&ccolor); #ifdef C4D_R12 bc->SetVector(PLANETX_CLOUD_COLOR, ccolor); #else bc->SetVector(PLANETX_CLOUD_COLOR, Vector(ccolor.x, ccolor.y, ccolor.z)); #endif //Brightness LReal cbright; bf->ReadLReal(&cbright); bc->SetReal(PLANETX_CLOUD_BRIGHTNESS, cbright); //Thickness LReal cthick; bf->ReadLReal(&cthick); bc->SetReal(PLANETX_CLOUD_THICKNESS, cthick); //Elevation LReal celeva; bf->ReadLReal(&celeva); bc->SetReal(PLANETX_CLOUD_ELEVATION, celeva); //Enable Shadows Bool enshad; bf->ReadBool(&enshad); bc->SetBool(PLANETX_CLOUD_ENABLE_SHADOWS, enshad); //ATMOSPHERE //==========================================================// //Enable Atmosphere Bool enatmo; bf->ReadBool(&enatmo); bc->SetBool(PLANETX_ATMOSPHERE_ENABLE, enatmo); //Atmosphere Color Gradient *atmColor =(Gradient* )bc->GetCustomDataType(PLANETX_ATMOSPHERE_COLOR,CUSTOMDATATYPE_GRADIENT); Gradient *blank = Gradient::Alloc(); LONG knotCount; bf->ReadLong(&knotCount); bc->SetParameter((DescID)(DescID)PLANETX_ATMOSPHERE_COLOR, GeData(CUSTOMDATATYPE_GRADIENT, *blank)); for(int i = 0; i < knotCount; i++){ LVector color; LReal position; bf->ReadLVector(&color); bf->ReadLReal(&position); GradientKnot knot; Vector tmpcol = Vector(color.x, color.y, color.z); knot.col = tmpcol; knot.pos = position; atmColor->InsertKnot(knot); } bc->SetParameter((DescID)(DescID)PLANETX_ATMOSPHERE_COLOR, GeData(CUSTOMDATATYPE_GRADIENT, *atmColor)); //Transparency Color Gradient *atmtColor =(Gradient* )bc->GetCustomDataType(PLANETX_ATMOSPHERE_TRANSPARENCY, CUSTOMDATATYPE_GRADIENT); Gradient *tblank = Gradient::Alloc(); LONG tknotCount; bf->ReadLong(&tknotCount); bc->SetParameter((DescID)(DescID)PLANETX_ATMOSPHERE_TRANSPARENCY, GeData(CUSTOMDATATYPE_GRADIENT, *tblank)); for(int i = 0; i < tknotCount; i++){ LVector tcolor; LReal tposition; bf->ReadLVector(&tcolor); bf->ReadLReal(&tposition); GradientKnot tknot; Vector ttmpcol = Vector(tcolor.x, tcolor.y, tcolor.z); tknot.col = ttmpcol; tknot.pos = tposition; atmtColor->InsertKnot(tknot); } bc->SetParameter((DescID)(DescID)PLANETX_ATMOSPHERE_TRANSPARENCY, GeData(CUSTOMDATATYPE_GRADIENT, *atmtColor)); //Haze Color LVector ahazecolor; bf->ReadLVector(&ahazecolor); #ifdef C4D_R12 bc->SetVector(PLANETX_ATMOSPHERE_HAZE_COLOR, ahazecolor); #else bc->SetVector(PLANETX_ATMOSPHERE_HAZE_COLOR, Vector(ahazecolor.x, ahazecolor.y, ahazecolor.z)); #endif //Atmosphere Thickness LReal athick; bf->ReadLReal(&athick); bc->SetReal(PLANETX_ATMOSPHERE_THICKNESS, athick); //Enable Glow Bool eng; bf->ReadBool(&eng); bc->SetBool(PLANETX_ATMOSPHERE_ENABLE_GLOW, eng); //Use Material Color Bool emc; bf->ReadBool(&emc); bc->SetBool(PLANETX_ATMOSPHERE_GLOW_USE_COLOR, emc); //Glow Color LVector gcolor; bf->ReadLVector(&gcolor); #ifdef C4D_R12 bc->SetVector(PLANETX_ATMOSPHERE_GLOW_COLOR, gcolor); #else bc->SetVector(PLANETX_ATMOSPHERE_GLOW_COLOR, Vector(gcolor.x, gcolor.y, gcolor.z)); #endif //Brightness LReal gbrit; bf->ReadLReal(&gbrit); bc->SetReal(PLANETX_ATMOSPHERE_GLOW_BRIGHTNESS, gbrit); //Inner Strength LReal gis; bf->ReadLReal(&gis); bc->SetReal(PLANETX_ATMOSPHERE_GLOW_INNERSTRENGTH, gis); //Outer Strength LReal gos; bf->ReadLReal(&gos); bc->SetReal(PLANETX_ATMOSPHERE_GLOW_OUTERSTRENGTH, gos); //Radius LReal grad; bf->ReadLReal(&grad); bc->SetReal(PLANETX_ATMOSPHERE_GLOW_RADIUS, grad); //Random LReal grand; bf->ReadLReal(&grand); bc->SetReal(PLANETX_ATMOSPHERE_GLOW_RANDOM, grand); //Frequency LReal gfreq; bf->ReadLReal(&gfreq); bc->SetReal(PLANETX_ATMOSPHERE_GLOW_FREQUENCY, gfreq); //LIGHTS //==========================================================// //Enable Lights Bool elts; bf->ReadBool(&elts); bc->SetBool(PLANETX_LIGHTS_ENABLE, elts); //City Lights Map Filename lmap; bf->ReadFilename(&lmap); bc->SetFilename(PLANETX_CITY_LIGHTS_MAP,lmap); //Brightness LReal ltsbrt; bf->ReadLReal(<sbrt); bc->SetReal(PLANETX_CITY_LIGHTS_BRIGHTNESS, ltsbrt); //Lights Color LVector ltscolor; bf->ReadLVector(<scolor); #ifdef C4D_R12 bc->SetVector(PLANETX_CITY_LIGHTS_COLOR, ltscolor); #else bc->SetVector(PLANETX_CITY_LIGHTS_COLOR, Vector(ltscolor.x, ltscolor.y, ltscolor.z)); #endif return TRUE; }
This works great when I save the file in Windows and open the file in Windows,, The problem arises when I save the file with a PC and try to open it with a Mac. My Mac tester tells me that the plugin loads fine but none of the preset files oad properly. I assume that this is an issue with the ByteOrder but I do not know how to account for the different operating systems with a function like this. Does anyone know how to allow a file that was saved on a PC via my SavePresets() function, to be opened on a Mac?
Any help you could offer would be awesome.
Thanks,
Shawn
On 16/05/2011 at 23:55, xxxxxxxx wrote:
As far as I know, the only area that has byteorder concern is WriteBytes and ReadBytes. Everything else should be system independent as long as you stick with the same byte order across the board.
I have had issues with Real, SReal, and LReal in transitioning from RXX to R12 though. In this case, it required using WriteSReal/ReadSReal to make things work.
Considering that most contemporary Mac computers are using Intel it seems odd that there would be any issues between PC and Mac. My suggestion is to do tests with the minimal settings being written and read and expand them until the issue appears so as to see if it is related to a certain type (esp. Reals!). Remember that it could also be a 32-bit/64-bit issue. Size of types varies between systems and bit width (unfortunately). You may need to compensate for that as well.
On 17/05/2011 at 07:35, xxxxxxxx wrote:
How do you write the presetfiles ? If not with functions from C4D, then with C++ standart library methods i think ?
As I know from Python, Windows writes some additional bytes at the start of a document, as far as I remember. There, you must open the file anogher way. 'wb' instead of 'w', so that no extra bytes are written. Maybe its the same in C++, and readinh the file on Mac makes problems because of theese additional bytes ?
Cheers, Niklas
On 17/05/2011 at 10:22, xxxxxxxx wrote:
I write the files the same as above but using the C4D Write...() functions instead of read.. and a few subtle differences of course I am not sure why it is happening. I really need to invest in a Mac in the near future, I don't like being in the dark on the Mac side of things. ~Shawn
On 17/05/2011 at 17:20, xxxxxxxx wrote:
OMG this is so annoying.. I changed all the LReals to SReals and it still did not work.. The plugin will not load the preset file.. Here is the SavePreset() :
//SAVE PRESET //====================================================// Bool PXGPlanet::SavePreset(GeListNode* node){ BaseObject *op = (BaseObject* )node; BaseContainer *bc = op->GetDataInstance(); //Declare the BaseFile AutoAlloc<BaseFile> bf; //Set the Filename Filename file; Filename dir = GeGetPluginPath() + "presets/planets"; file.SetDirectory(dir); #ifdef C4D_R12 file.FileSelect(FILESELECTTYPE_ANYTHING, FILESELECT_SAVE, "Save Your Preset"); //Open the BaseFile for writing. bf->Open(file, FILEOPEN_WRITE, FILEDIALOG_IGNOREOPEN, BYTEORDER_INTEL, MACTYPE_CINEMA, MACCREATOR_CINEMA); #else file.FileSelect(FSTYPE_ANYTHING, GE_SAVE, "Save Your Preset"); //Open the BaseFile for writing. bf->Open(file, GE_WRITE, FILE_IGNOREOPEN, GE_INTEL, MACTYPE_CINEMA, MACCREATOR_CINEMA); #endif //Write PXG Attributes to the File. //GENERAL //==========================================================// //General Shape bf->WriteLong(bc->GetLong(PLANETX_GENERAL_SHAPE)); //Radius bf->WriteLReal(bc->GetReal(PLANETX_GENERAL_RADIUS)); //Segments bf->WriteLReal(bc->GetReal(PLANETX_GENERAL_SEGMENTS)); //Height bf->WriteLReal(bc->GetReal(PLANETX_GENERAL_HEIGHT)); //Enable Rotation bf->WriteBool(bc->GetBool(PLANETX_GENERAL_ENABLE_ROTATION)); //Rotation Direction bf->WriteLong(bc->GetLong(PLANETX_GENERAL_ROTATION_DIRECTION)); //Rotation Speed bf->WriteLReal(bc->GetReal(PLANETX_GENERAL_ROTATION_SPEED)); //Frame Rate FPS bf->WriteLReal(bc->GetReal(PLANETX_GENERAL_SCENEFPS)); //SURFACE //==========================================================// //Surface Map bf->WriteFilename(bc->GetFilename(PLANETX_SURFACE_SURFACE_MAP)); //Enable Specular bf->WriteBool(bc->GetBool(PLANETX_SURFACE_SPEC_ENABLE)); //Specular Mode bf->WriteLong(bc->GetLong(PLANETX_SURFACE_SPEC_MODE)); //Specular Width bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_SPEC_WIDTH)); //Specular Height bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_SPEC_HEIGHT)); //Specular Falloff bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_SPEC_FALLOFF)); //Specular Inner Width bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_SPEC_INNER_WIDTH)); //Enable Generator bf->WriteBool(bc->GetBool(PLANETX_SURFACE_ENABLE_GENERATOR)); #ifdef C4D_R12 //Sea Color bf->WriteLVector(bc->GetVector(PLANETX_SURFACE_SEA_COLOR)); //Land Color bf->WriteLVector(bc->GetVector(PLANETX_SURFACE_LAND_COLOR)); //Mountain Color bf->WriteLVector(bc->GetVector(PLANETX_SURFACE_MOUNTAIN_COLOR)); #else //Helpers Vector sea1 = bc->GetVector(PLANETX_SURFACE_SEA_COLOR); Vector land1 = bc->GetVector(PLANETX_SURFACE_LAND_COLOR); Vector mtn1 = bc->GetVector(PLANETX_SURFACE_MOUNTAIN_COLOR); //Sea Color bf->WriteLVector(LVector(sea1.x, sea1.y, sea1.z)); //Land Color bf->WriteLVector(LVector(land1.x, land1.y, land1.z)); //Mountain Color bf->WriteLVector(LVector(mtn1.x, mtn1.y, mtn1.z)); #endif //Level bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_LEVEL)); //Frequnecy bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_FREQUENCY)); //Generator Reflection bf->WriteBool(bc->GetBool(PLANETX_SURFACE_GENERATOR_USE_REFLECTION)); //Generator Elevation bf->WriteBool(bc->GetBool(PLANETX_SURFACE_GENERATOR_USE_ELEVATION)); //Reflection Strength bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_SURFACE_REFLECTION_GEN)); //Elevation Strength bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_ELEVATION_STRENGTH_GEN)); //Use Reflection Map bf->WriteBool(bc->GetBool(PLANETX_SURFACE_REFLECTION_USE_MAP)); //Reflection Map bf->WriteFilename(bc->GetFilename(PLANETX_SURFACE_REFLECTION_MAP)); //Reflection Mix bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_SURFACE_REFLECTION_MMIX)); //Surface Reflection bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_SURFACE_REFLECTION)); //Elevation Map bf->WriteFilename(bc->GetFilename(PLANETX_SURFACE_ELEVATION_MAP)); //Elevation Strength bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_ELEVATION_STRENGTH)); //Use Normal Map bf->WriteBool(bc->GetBool(PLANETX_SURFACE_USE_NORMAL_MAP)); //Normal Map bf->WriteFilename(bc->GetFilename(PLANETX_SURFACE_NORMAL_MAP)); //Normal Strength bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_NORMAL_STRENGTH)); //CLOUDS //==========================================================// //Enable Clouds bf->WriteBool(bc->GetBool(PLANETX_CLOUDS_ENABLE)); //Cloud Map bf->WriteFilename(bc->GetFilename(PLANETX_CLOUD_CLOUD_MAP)); #ifdef C4D_R12 //Cloud Color bf->WriteLVector(bc->GetVector(PLANETX_CLOUD_COLOR)); #else //Helper Vector cldclr = bc->GetVector(PLANETX_CLOUD_COLOR); bf->WriteLVector(LVector(cldclr.x, cldclr.y, cldclr.z)); #endif //Brightness bf->WriteLReal(bc->GetReal(PLANETX_CLOUD_BRIGHTNESS)); //Thickness bf->WriteLReal(bc->GetReal(PLANETX_CLOUD_THICKNESS)); //Elevation bf->WriteLReal(bc->GetReal(PLANETX_CLOUD_ELEVATION)); //Use Particles bf->WriteBool(bc->GetBool(PLANETX_CLOUD_ENABLE_SHADOWS)); //ATMOSPHERE //==========================================================// //Enable Atmosphere bf->WriteBool(bc->GetBool(PLANETX_ATMOSPHERE_ENABLE)); //Atmosphere Color Gradient *atmColor =(Gradient* )bc->GetCustomDataType(PLANETX_ATMOSPHERE_COLOR,CUSTOMDATATYPE_GRADIENT); LONG knotCount = atmColor->GetKnotCount(); bf->WriteLong(knotCount); for(int i = 0; i < knotCount; i++){ GradientKnot knot = atmColor->GetKnot(i); #ifdef C4D_R12 bf->WriteLVector(knot.col); #else //Helper Vector mycol = knot.col; bf->WriteLVector(LVector(mycol.x, mycol.y, mycol.z)); #endif bf->WriteLReal(knot.pos); } //Transparency Color Gradient *atmtColor =(Gradient* )bc->GetCustomDataType(PLANETX_ATMOSPHERE_TRANSPARENCY, CUSTOMDATATYPE_GRADIENT); LONG tknotCount = atmtColor->GetKnotCount(); bf->WriteLong(tknotCount); for(int i = 0; i < tknotCount; i++){ GradientKnot tknot = atmtColor->GetKnot(i); #ifdef C4D_R12 bf->WriteLVector(tknot.col); #else //Helper Vector mytcol = tknot.col; bf->WriteLVector(LVector(mytcol.x, mytcol.y, mytcol.z)); #endif bf->WriteLReal(tknot.pos); } #ifdef C4D_R12 //Haze Color bf->WriteLVector(bc->GetVector(PLANETX_ATMOSPHERE_HAZE_COLOR)); #else //Helper Vector hzcol = bc->GetVector(PLANETX_ATMOSPHERE_HAZE_COLOR); bf->WriteLVector(LVector(hzcol.x, hzcol.y, hzcol.z)); #endif //Atmosphere Thickness bf->WriteLReal(bc->GetReal(PLANETX_ATMOSPHERE_THICKNESS)); //Enable Glow bf->WriteBool(bc->GetBool(PLANETX_ATMOSPHERE_ENABLE_GLOW)); //Use Material Color bf->WriteBool(bc->GetBool(PLANETX_ATMOSPHERE_GLOW_USE_COLOR)); //Glow Color #ifdef C4D_R12 bf->WriteLVector(bc->GetVector(PLANETX_ATMOSPHERE_GLOW_COLOR)); #else //Helper Vector glcol = bc->GetVector(PLANETX_ATMOSPHERE_GLOW_COLOR); bf->WriteLVector(LVector(glcol.x, glcol.y, glcol.z)); #endif //Brightness bf->WriteLReal(bc->GetReal(PLANETX_ATMOSPHERE_GLOW_BRIGHTNESS)); //Inner Strength bf->WriteLReal(bc->GetReal(PLANETX_ATMOSPHERE_GLOW_INNERSTRENGTH)); //Outer Strength bf->WriteLReal(bc->GetReal(PLANETX_ATMOSPHERE_GLOW_OUTERSTRENGTH)); //Radius bf->WriteLReal(bc->GetReal(PLANETX_ATMOSPHERE_GLOW_RADIUS)); //Random bf->WriteLReal(bc->GetReal(PLANETX_ATMOSPHERE_GLOW_RANDOM)); //Frequency bf->WriteLReal(bc->GetReal(PLANETX_ATMOSPHERE_GLOW_FREQUENCY)); //LIGHTS //==========================================================// //Enable Lights bf->WriteBool(bc->GetBool(PLANETX_LIGHTS_ENABLE)); //City Lights Map bf->WriteFilename(bc->GetFilename(PLANETX_CITY_LIGHTS_MAP)); //Brightness bf->WriteLReal(bc->GetReal(PLANETX_CITY_LIGHTS_BRIGHTNESS)); //Lights Color #ifdef C4D_R12 bf->WriteLVector(bc->GetVector(PLANETX_CITY_LIGHTS_COLOR)); #else //Helper Vector clcol = bc->GetVector(PLANETX_CITY_LIGHTS_COLOR); bf->WriteLVector(LVector(clcol.x, clcol.y, clcol.z)); #endif bc->SetString(PXG_CURRENT_PRESET_TEXT, file.GetFileString()); bf->Close(); //READ ONLY if(bc->GetBool(PLANETX_GENERAL_SAVE_READONLY) == TRUE){ #ifdef C4D_R10 GePrint("THIS FEATURE IS NOT AVAILABLE IN R10"); #else GeFSetAttributes(file, GE_FILE_ATTRIBUTE_READONLY, GE_FILE_ATTRIBUTE_READONLY); GePrint("FILE SAVED AS READ ONLY"); #endif } return TRUE; }
Does anyone notice anything I botched up that would prevent it from working on a Mac?
Man this is annoying me tonight. Thanks,
~Shawn
On 17/05/2011 at 23:13, xxxxxxxx wrote:
Originally posted by xxxxxxxx [...] Does anyone notice anything I botched up that would prevent it from working on a Mac?Man this is annoying me tonight.Thanks,~Shawn
Do yourself a favour and implement some basic error checking in the code and add some detailed console error messages for the customer/tester.
Best regards,
Wilfried
On 20/05/2011 at 05:48, xxxxxxxx wrote:
okay so after some testing, we have determined that the save preset function is saving Filenames from the attributes manager with full paths. So for example the plugin uses external textures like test.jpg. So the filename field gets saved as (doing this on my phone and don't havr backslash) C:/Program Files/Maxon/Plugins/PXG Planet/Presets/Test.jpg. So when that prset gets opened on a mac that path doesn't exist which leads to the preset not opening properly. How can I get the preset to save the file name and location so that it can ne read by both Mac ane Windos folder structures?
Thanks. Shawn
On 20/05/2011 at 09:54, xxxxxxxx wrote:
To save just the file name itself, use this:
Filename fn = bc->GetFilename(xxx); fn = fn.GetFile();
As for location, that will vary from system to system (Windows, MacOS, drive or volume, etc.). Best to use GeGetPluginPath() to prepend to the filename after reading and just store the file name (Test.jpg) in the presets file.
