On 28/04/2011 at 10:41, xxxxxxxx wrote:
when writing Python Plugins with descriptions for Cinema 4D (Object,Tag,Toolplugin, etc ..), one often has to delete the coffeesymbolcache to make changes is the .res files appear.
I've written a small Python plugin in order to make this directly in Cinema 4D quickly.
Before using, you should copy the path of coffesymbolcache file to the paths.txt file. You can also add other paths. "//" will be ignored as well as nonexisting paths.
Open Source, free for all.
Cleaner.rar
Cheers.
