doc.AddUndo with Selection
On 27/04/2011 at 05:57, xxxxxxxx wrote:
Hi.
I'm having trouble with doc.AddUndo(c4d.UNDOTYPE_CHANGE_SELECTION,op).
After executing the code, c4d jumps 2 Steps backwards, and not 1, clicking on Undo.
            original    = op.GetPointS()
          point_sel.CopyTo(original)
Any Idea ?
Cheers, nux
On 27/04/2011 at 12:38, xxxxxxxx wrote:
Can you please post more lines or an example which reproduces this behave?
On 27/04/2011 at 17:51, xxxxxxxx wrote:
Of course, sorry.
sel = c4d.BaseSelect()
sel.CopyTo(op.GetPolygonS())
1. Create a Polygonobject.
2. Select some Polys
3. Again select some other Polys
4. Execute the script
5. Do undo
And you'll see the first polygon selection, not the second you've done. 😠
Cheers, nux
//edit:
I think I could figure out the issue, let me just try that.
(Start/EndUndo missing)
Hm, this code works:
doc.StartUndo()
doc.EndUndo()
But i just don't get it to work in my plugin.
In this case it just copys a selection to the corresponding selection for the mode.
        doc.StartUndo()
      if mode     == c4d.Mpoints:
          point_sel.CopyTo(op.GetPointS())
      elif mode   == c4d.Mpolygons:
          poly_sel.CopyTo(op.GetPolygonS())
      elif mode   == c4d.Medges:
          point_sel_cache     = op.GetPointS().GetClone()     #Save the current pointselection
          point_sel.CopyTo(op.GetPointS())                    #Copy Pointselection to Object
          bc      = c4d.BaseContainer()                       #BaseContainer holding Data for MC
          bc[c4d.MDATA_CONVERTSELECTION_LEFT]     = 0         #Convert Points
          bc[c4d.MDATA_CONVERTSELECTION_RIGHT]    = 1         #to Edges
          bc[c4d.MDATA_CONVERTSELECTION_TOLERANT] = False     #Tolerance gives wrong results
          bc[c4d.SELECTION_NEW]                   = True
          SendModelingCommand(        command     = c4d.MCOMMAND_CONVERTSELECTION,
                                      list        = [op],
                                      doc         = op.GetDocument(),
                                      bc          = bc
          point_sel_cache.CopyTo(op.GetPointS())              #Restore Pointselection Cache
      doc.EndUndo()
What undo-stuff did i miss here ? 😕
On 29/04/2011 at 09:02, xxxxxxxx wrote:
Any idea ?
On 01/05/2011 at 23:45, xxxxxxxx wrote:
*push*
On 04/05/2011 at 05:06, xxxxxxxx wrote:
The code seems to be fine. I can't explain the behave yet.
On 05/05/2011 at 04:59, xxxxxxxx wrote:
Would be nice if you could find a solution.
Thanks in advance,
Niklas
