On 12/04/2011 at 10:07, xxxxxxxx wrote:
the python documentation states for DrawViews(...) : "Redraws the editor views. Must be called from the main thread!"
So, how do I control which thread is calling my Python Node (or how to know which thread is calling)? When I try to call the "add" button within the Mograph-Multishader by python:
multishader = material[c4d.MATERIAL_COLOR_SHADER]; c4d.CallButton(multishader, 1002) #MGMULTISHADER_ADD = 1002,
I get the error: RuntimeError: Illegal operation. Invalid cross-thread call.
This happens from a Python Node within XPresso. How can I prevent/control that ?
Thank you, maxx
On 12/04/2011 at 12:14, xxxxxxxx wrote:
This is not documentated for nodes yet. The hooks for Python in the Python Generator, Python Tag and Python Node are called in a threaded context. Within this hooks you should never call GUI stuff or change the document hierarchy. Methods which are called in a threaded context are documentated with this note:
Important: This function is called in a thread context. _ _ What exactly do you want to achieve? Maybe there is a workaround for this.
On 12/04/2011 at 14:23, xxxxxxxx wrote:
Hy there,
my goal is to automate the loading of Bitmap-Shaders into the MoGraph multi-shader.
I already tried to insert the shader directly to the multishader:
shn = c4d.BaseList2D(c4d.Xbitmap) mat[c4d.MATERIAL_COLOR_SHADER] = shn material.InsertShader(shn,sh) material.Message(c4d.MSG_UPDATE) material.Update(True,True) c4d.EventAdd()
But this will not work. Actually, the shader is in the (internal) list, but it won't show up in the multi-shader and also has no effect.
So I tried to use the "Add" button, to add the shaders. Yea, desperate measures
Is it then possible to add a hook from within a Python Node which gets called by the main-thread?
Can you give me an example, how to use that CallButton(..) function in the right context ?
On 01/06/2011 at 09:35, xxxxxxxx wrote:
Sorry for the late reply. I will check out if I can provide you with an example.
On 02/06/2011 at 08:26, xxxxxxxx wrote:
.. that would be nice, thank you
On 21/04/2014 at 13:36, xxxxxxxx wrote:
curious if you ever found a solution. Running into this now too. Seems kind of silly we can't call a button in a pynode
On 02/05/2014 at 06:27, xxxxxxxx wrote:
It's by design. A button could do things that you really don't want to happen from an Expression. Use c4d.SpecialEventAdd() and listen to it with a MessageData plugin. That's one of the work arounds, but it's not possible without coding a real plugin.
-Niklas
On 02/05/2014 at 16:06, xxxxxxxx wrote:
Dang! I'll look into the SpecialEventAdd. Thanks Niklas.
