On 03/04/2011 at 06:41, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11.5&12 Platform: Windows ; Mac ; Language(s) : C.O.F.F.E.E ;
--------- Hi !
I created a MenuPlugin that opens a dialog, my problem is that each time I run the menuplugin its opens a new instance of the dialog ... I tried multiple tricks but didn't really found the equivalent of the MultipleAllowed() of the expression tag plugin.
Any idea welcome.
Thanks !
Mike
On 03/04/2011 at 07:06, xxxxxxxx wrote:
Could you provide a snippet of code to show how you call for the dialogue to open? Might help us help you.
Thanks,
Shawn
On 03/04/2011 at 08:49, xxxxxxxx wrote:
Simply :
Plugin::Execute(doc) { dialog = new(plugintools_gui); dialog->Open(TRUE,-1,-1); }
plugintools_gui is a GeDialog derived class and Plugin a menuplugin
Hope it's enough.
On 03/04/2011 at 10:07, xxxxxxxx wrote:
is it possible to check if there is an instance dialog already in use?
On 03/04/2011 at 12:14, xxxxxxxx wrote:
hello, first of all use restorelayout metod in dialog and command .... then if you need a pointer to the dialog from other part of cinema you have to create a kind of singletone of your command data and retrive the pointer from it. in activeobject there is an example of this! if you need some more help tell me .. i can share some example.
all the best Franz
On 03/04/2011 at 12:15, xxxxxxxx wrote:
sorry i never seen is a coffee problem ... my reply was refereed to c++
sorry Franz
On 03/04/2011 at 13:25, xxxxxxxx wrote:
Thanks Franz... No problem, I often have this problem too
Shawn : In fact I already tested something like
if (!dialog) { dialog = new(plugintools_gui); dialog->Open(TRUE,-1,-1); }
But even when closed, the dialog object stays as existing. The result in cinema4d is that once I close the plugin dialog I cannot run it anymore because if (!dialog) always returns false.
On 03/04/2011 at 15:51, xxxxxxxx wrote:
Here is how I do it. It will not reopen the dialog if already open and supports adding it to the layout:
//////////////////////////////////////////////////////////////// // dropobject.cof //////////////////////////////////////////////////////////////// // Drop object onto target object or floor (X-Z plane). // - If no object intersection, alert user. //////////////////////////////////////////////////////////////// // V0.3 2005.02.20 (c) Robert Templeton //////////////////////////////////////////////////////////////// // Included symbols include "c4d_symbols.h" // Global references var resource; var plugin_path; var plugin_icon; var d; include "floordialog.h" // CLASS: Drop Object Menu - Register plugin in menu class DropObject_MenuPlugin : MenuPlugin { public: DropObject_MenuPlugin(); GetID(); GetIcon(); GetName(); GetHelp(); Execute(doc); RestoreLayout(secret); } DropObject_MenuPlugin::DropObject_MenuPlugin() { super(); } DropObject_MenuPlugin::GetID() { return PLUGIN_MENU_ID; } DropObject_MenuPlugin::GetIcon() { return plugin_icon; } DropObject_MenuPlugin::GetName() { return resource->GetString(PLUGIN_MENU_TEXT); } DropObject_MenuPlugin::GetHelp() { return resource->GetString(PLUGIN_MENU_HELP_TEXT); } DropObject_MenuPlugin::Execute(doc) { // Perform operation d->Open(TRUE,-1,-1); } DropObject_MenuPlugin::RestoreLayout(secret) { // Called by C4D to restore the dialog if (!d) d = new(FloorDialog); d->RestoreLayout(secret); } // Start of plugin main() { // Load Resource if (!(plugin_path = GeGetRootFilename())) println("Unable to find plugin!"); plugin_path->RemoveLast(); if (!(resource = new(GeResource, plugin_path))) println("Unable to load resource!"); // Load Icons var icon_file = plugin_path->GetClone(); icon_file->AddLast("pluginicon.tif"); plugin_icon = new(BaseBitmap,1,1); plugin_icon->Load(icon_file); // Register Plugins Register(DropObject_MenuPlugin); // Create non-modal dialog d = new(FloorDialog); }
On 03/04/2011 at 16:34, xxxxxxxx wrote:
Ok, so if I understand well, the key was to declare the floordialog object only ONE time when launching cinema4d, this way it avoids to get multiple instances ...this is as brilliant as it seems obvious now ...
You're my hero once more
Thanks everyone.
M!ke
