move the axis ??
On 01/04/2011 at 04:58, xxxxxxxx wrote:
Hi.
I want to move the axis of the object in a script.
What should be carried out in what way?
On 01/04/2011 at 05:56, xxxxxxxx wrote:
I don't know a comfortable way to solve this. You have to move the points of the Object, instead of the axis itself, and then move the hole object (including the axis of course ;] ) again in that negative direction..
Try this example 😉
from   c4d import gui
def err_message() :
  gui.MessageDialog("Please enter a vector!")
def main() :
  vec       = gui.InputDialog("X Axis Offset","c4d.Vector(0,100,0)")
  try: vec  = eval(vec)
  except: pass
  if not isinstance(vec,c4d.Vector) :
      err_message()
      return False
  print     "Axis Offset: %s" % vec
  points    = op.GetAllPoints()
  for i in range(len(points)) :
      points[i] = points[i]+(vec*(-1))
  op.SetAbsPos(op.GetAbsPos()+vec)
  op.SetAllPoints(points)
  op.Message(c4d.MSG_UPDATE)
if __name__=='__main__':
Greets, nux
On 01/04/2011 at 20:58, xxxxxxxx wrote:
Thanks Nux
'll try this way!
