On 01/04/2011 at 01:59, xxxxxxxx wrote:
I was hoping to get some advice on how to properly use the following functions that are part of c4d.BaseSelect()
Snippets that don't work as I would expect
#Select all points and polys point_select.SelectAll(0, point_count) poly_select.SelectAll(0, poly_count)
My Full Source Code
""" Select All Polygons ------------------------------- Open Source - Free for all Originally written by: Donovan Keith [email protected] Last Edit: 04/01/2011 """ import c4d from c4d import gui, documents def main() : #Get active document doc = documents.GetActiveDocument() if not doc: gui.MessageDialog("No active document.") return False #Get first active object op = doc.GetActiveObject() if not op or not op.CheckType(c4d.Opolygon) : gui.MessageDialog("No poly objected selected") return False #Get point and polygon selections and counts point_select = op.GetPointS() poly_select = op.GetPolygonS() point_count = op.GetPointCount() poly_count = op.GetPolygonCount() #Select all points and polys point_select.SelectAll(0, point_count) poly_select.SelectAll(0, poly_count) #Alert C4D something has changed c4d.EventAdd() if __name__=='__main__': main()
What am I doing incorrectly? I can properly select and deselect elements using .Select() and .Deselect(), but no joy otherwise. Thanks,
Donovan
On 01/04/2011 at 03:11, xxxxxxxx wrote:
Hi, did you upgrade to R12.043? There are some fixes in BaseSelect. Cheers, Sebastian
On 01/04/2011 at 17:36, xxxxxxxx wrote:
Hi Sebastian,
Yes, I'm running 12.043. Does my script as posted above select all points and polygons for you, as it does nothing here? Thanks,
On 01/04/2011 at 17:53, xxxxxxxx wrote:
Your script seems to be alright. Alternatively, you can use this:
def SelectAll(bs,max) : for i in range(max) : bs.Select(i)
Cheers, nux
On 20/05/2011 at 14:18, xxxxxxxx wrote:
Okay, for whatever reason the bs.SelectAll(min,max) function is not working for me, but bs.Select(i) is. Thanks nux95!
On 20/05/2011 at 15:01, xxxxxxxx wrote:
bs.ToggleAll() isn't working for me either. Odd. Can anyone else confirm that these functions aren't working? Or is it something to do with my installation?
On 01/06/2011 at 09:32, xxxxxxxx wrote:
@Donovan: What is wrong with ToggleAll? It works fine here (r12.043).
