Python Bug - RenderDocument results in black Image
On 24/03/2011 at 06:56, xxxxxxxx wrote:
Cinema 4D Version: R12
Platform: Mac ;
Language(s) :---------
Hey guys,just started learning Python and stumbled on a problem what is apparently a bug. When I render the image with my script and show it in the picture viewer, the resulting image is just black.
Here's the script I use:
import c4d from c4d import bitmaps, documents doc = documents.GetActiveDocument() rd = doc.GetActiveRenderData().GetData() res_x = 512 # image resolution x res_y = 512 # image resolution y bitdepth = 8 # image depth bmp = bitmaps.BaseBitmap() bmp.Init(x=res_x, y=res_y, depth=bitdepth) documents.RenderDocument(doc, rd, bmp, c4d.RENDERFLAGS_EXTERNAL) bitmaps.ShowBitmap(bmp)
On 24/03/2011 at 10:23, xxxxxxxx wrote:
Hi pelZ,
The bit depth in your code is not correct.
Cheers, Sebastian
bitdepth = 24 # image depth
On 24/03/2011 at 11:56, xxxxxxxx wrote:
Originally posted by xxxxxxxx
Hi pelZ,
Cheers, Sebastian
Hi Sebastian,
that fixes the problem. Thanks!
But why is it 24 (16 and 32 seem to work as well)?Ciao,
Philipp
On 24/03/2011 at 16:59, xxxxxxxx wrote:
16 bit works fine as well but the image has a lower quality.
On 24/03/2011 at 22:38, xxxxxxxx wrote:
When you render an Image "with 8 Bit" it is 8 Bit per Channel, not the overall bitdepth.
There are 3 Channels. (RGB)
3 * 8 = 24With Alpha, there are 4 Channels.
4 * 8 = 32Higher Bitdepths per Channel:
4 * 32 = 128Cheers, nux
