On 22/03/2011 at 05:27, xxxxxxxx wrote:
--------- Hello,
I'm searching for a command, to get the information if the animation is running or not. And maybe, if a command exist to start or stop the animation !
thanks Marky
On 23/03/2011 at 06:37, xxxxxxxx wrote:
Howdy,
To check if the animation is running you can use:
if(CheckIsRunning(CHECKISRUNNING_ANIMATIONRUNNING))
... and these should control the animation play:
CallCommand(12411); // Play Backwards CallCommand(12412); // Play Forwards CallCommand(12002); // Stop Play
Adios, Cactus Dan
On 23/03/2011 at 07:06, xxxxxxxx wrote:
grandiose, it works
thanks a lot
On 24/03/2011 at 08:10, xxxxxxxx wrote:
You're welcome.
You can also use this global function from c4d_basedocument:
void RunAnimation([BaseDocument](file:///Users/danlibisch/Documentation/C4D%20Manuals/R10%20SDK/pages/c4d_basedocument/class_BaseDocument47.html)* doc, Bool forward, Bool stop)_<_h4_>_ Controls the animation in the active document doc. <_<_h5_>_h5> _Paramet_ <_h5_>_i> > [BaseDocument](file:///Users/danlibisch/Documentation/C4D%20Manuals/R10%20SDK/pages/c4d_basedocument/class_BaseDocument47.html)* doc > >> The document to control. Usually [_tivevoid">GetActiveDocument()](file:///Users/danlibisch/Documentation/C4D%20Manuals/R10%20SDK/pages/c4d_basedocument/global_c4d_basedocum120.html#getactivedocument0 " c4d_::getactivevoid"). The caller owns the pointed object. > > Bool forward > >> If this is [TRUE](file:///Users/danlibisch/Documentation/C4D%20Manuals/R10%20SDK/pages/ge_math/enum_BoolConstants96.html#TRUE1) the direction is set to forward, otherwise it's set to backward. > > Bool stop > >> If this is [TRUE](file:///Users/danlibisch/Documentation/C4D%20Manuals/R10%20SDK/pages/ge_math/enum_BoolConstants96.html#TRUE1) the animation is stopped, otherwise it's running.
