On 17/03/2011 at 13:35, xxxxxxxx wrote:
I am still new to C4D Python but not Python in general.
I was wondering how one would go about grouping some objects of a selection into a group, as in selecting some objects in the Object Manager and hitting Ctrl+G/Cmd+G. It would be great if there is some sort of a command that takes a list of c4d objects and groups them.
However, I have been looking at the Python class hierarchy of the c4d module but I wasn't able to find something to do with grouping.
Thanks for reading!
Andre
On 17/03/2011 at 14:28, xxxxxxxx wrote:
def GetHNext(op) : if not op: return if op.GetDown() : return op.GetDown() while not op.GetNext() and op.GetUp() : op = op.GetUp() return op.GetNext() def GetActiveObjects(doc) : lst = list() op = doc.GetFirstObject() while op: if op.GetBit(c4d.BIT_ACTIVE) == True: lst.append(op) op = GetHNext(op) return lst def Group(lst, copy) : null = c4d.BaseObject(c4d.Onull) if copy == True: lst = [i.GetClone() for i in lst] [obj.InsertUnder(null) for obj in lst] return null def main() : lst = GetActiveObjects(doc) op = Group(lst,True) doc.InsertObject(op) c4d.EventAdd()
Is this what you are looking for ?
PS: I'm sorry if there's any mistake in list comprehension etc. I am currently on a mobile device.
On 17/03/2011 at 14:42, xxxxxxxx wrote:
That Group function is exactly what I was looking for. Thanks a lot!
One question, if I may:
Why the
in
GetHNext()
If you want to return next then why go down and stop there?
On 17/03/2011 at 14:47, xxxxxxxx wrote:
No problem.
You somewhere need to go down in the hierarchy. And going down has the highest priority while walking the hierarchy. Hard to explain, just test a bit with it.
Greets, Niklas
