SelectionTag
On 12/03/2011 at 08:26, xxxxxxxx wrote:
Is this class not finished yet ? GetSelection() does not work. And what about a SetSelection() function ?
On 12/03/2011 at 11:21, xxxxxxxx wrote:
Please use GetBaseSelect().
Cheers, Sebastian
On 12/03/2011 at 13:27, xxxxxxxx wrote:
Ah, Is it part of the SelectionTag Class ? Its not in the Sdk.
I'd rather need SetBaseSelect() or something.
And something likeMyPolygonObject.SetPolygonSelection(MyBaseSelectObject)
Thanks, nux
On 12/03/2011 at 14:24, xxxxxxxx wrote:
to set the selection you can manipulate the BaseSelect which you get by calling GetBaseSelect()
On 12/03/2011 at 17:52, xxxxxxxx wrote:
Ah, so this is a direct link to the BaseSelect? Would never ahve thought of this
I'll try this, thanks. :)
On 12/03/2011 at 20:37, xxxxxxxx wrote:
Here's a simple example using GetBaseSelect() just in case anyone needs it.
import c4d from c4d import gui def main() : obj = doc.GetFirstObject() tag = obj.GetFirstTag() # make sure the selection tag is the first one in the list of tags polycountOfObject = obj.GetPolygonCount()#How many polygons does the object have in total? selected = tag.GetBaseSelect()#Gets the selected polygons on the object countSelected = selected.GetCount()#how many polygons are selected? print "total polys in object = ", polycountOfObject print "total of selected polys = ", countSelected #Loop through the polys to get the selected one's index numbers for i in range(polycountOfObject) : if selected.IsSelected(i) : print i if __name__=='__main__': main()
On 13/03/2011 at 05:50, xxxxxxxx wrote:
Btw, you don't need to declare i before the for-loop.
And it was about setting selection, not getting. ;)Works perfect, Satara ! But i'd rather use SetSelection(BaseSelectObject). Unfortunately it's not possible
Cheers, nux
On 13/03/2011 at 07:48, xxxxxxxx wrote:
The methods BaseSelect.CopyTo and BaseSelect.GetClone might help you here.
