On 10/03/2011 at 11:36, xxxxxxxx wrote:
Hi everyone,
has anyone here managed to create a TP Group? I guess in theory it should be simple, but... well, this is what I tried:
import c4d def main() : tpGroup = tp.AllocParticleGroup() tpGroups = tp.GetParticleGroups(None,c4d.TP_GETPGROUP_ALL) tpAllGroup = tpGroups[0] tp.SetPGroupHierarchy(tpGroups[0],tpGroup,c4d.TP_INSERT_UNDERFIRST) if __name__=='__main__': main()
What I get is an error in PyTPGroup.cpp:341: bad argument to internal function
Does this look familiar to anyone?
On 11/03/2011 at 13:28, xxxxxxxx wrote:
Is this working for anyone?
On 12/03/2011 at 09:53, xxxxxxxx wrote:
Hi ripclaw, I can confirm that the group handling at this point doesn't work. Here is an alternative way to insert a new group into the group list:
import c4d def main() : root=tp.GetRootGroup() #get the root group "All" tpGroup = tp.AllocParticleGroup() tpGroup.SetName("TestGroup") tpGroup.InsertUnder(root) #insert new created group into group list c4d.EventAdd() #send global event message if __name__=='__main__': main()
Cheers, Sebastian
On 12/03/2011 at 10:20, xxxxxxxx wrote:
Thanks Sebastien!
I'll give it a try later.
On 12/03/2011 at 11:26, xxxxxxxx wrote:
Assigning the group worked that way, but finding it again via this:
tpGroups = tp.GetParticleGroups(tproot,c4d.TP_GETPGROUP_ALL)
throws the same error...
On 12/03/2011 at 11:30, xxxxxxxx wrote:
Unfortunately this error might occur in several situations when you handle tp groups. You can manually browse through the childs with tproot.GetDown().
On 12/03/2011 at 12:06, xxxxxxxx wrote:
Thanks again Sebastien. This appears to work, for anyone else who's trying it:
def findPGroup(self, root, searchname) : t = root.GetDown() if t == None: return None elif t.GetName() == searchname: return t else: self.findPGroup(t,searchname)
