On 09/03/2011 at 10:01, xxxxxxxx wrote:
Hi there,
I'll post this here again, because it's only about Python now.
I want to join the hierarchy of the selected Object to one. But The next objects are added, too, even they are NOT in the list ?!
import c4d from c4d import utils def GetHNext(op, start = None) : if not op: return if op.GetDown() : return op.GetDown() while (not op.GetNext()) and (op.GetUp()) : op = op.GetUp() if start == op: return return op.GetNext() return def GetHierarchyInList(op) : lst = list() sop = op while op: lst.append(op) op = GetHNext(op,sop) return lst def main() : lst = GetHierarchyInList(op) ## Get the Hierarchy of op if not lst[0]: return for i in lst: ## print all Objects in the list print i.GetName() obj = utils.SendModelingCommand(## Use modeling command command = c4d.MCOMMAND_JOIN, doc = doc, list = lst ) obj[0].SetAbsPos(c4d.Vector(0,250,0)) doc.InsertObject(obj[0]) ## Insert new Object doc.SetActiveObject(obj[0]) obj[0][c4d.ID_BASEOBJECT_COLOR] = c4d.Vector(130/255.0,255/255.0,100/255.0) c4d.EventAdd() if __name__=='__main__': main()
I have the following Hierarchy:
I select the Cube and in the list obtained by GetHierarchyInList(op) there is only the Cube and the Sphere, as wanted.
But at the end, all objects are collapsed by MCOMMAND_JOIN. Any Idea ?
Here an example scene, so you don't have to set up your own. click
Thanks, nux
On 13/03/2011 at 05:06, xxxxxxxx wrote:
*push*
On 14/03/2011 at 08:37, xxxxxxxx wrote:
Unfortunately I can't give you an answer on this right now. I have to check whats going on here.
On 14/03/2011 at 10:00, xxxxxxxx wrote:
There seems to be some SendModelingCommand options that are broken.
https://plugincafe.maxon.net/topic/5538/5558_mcommandjoin-bug
On 16/03/2011 at 08:46, xxxxxxxx wrote:
Thanks, i hope you can figure the problem out.
Unfortunately I can't use the CallCommand in my Plugin.
