On 01/07/2011 at 05:24, xxxxxxxx wrote:
i've sort of worked it out in a tag instead. if you create spline, add the tag to it, then link to a mesh in the tag, the tag will modify the spline so it goes through all the vertices of the mesh. gives exactly the same result as the tracer with deforms and sweepnurbs.
one problem is that the spline disapears in the viewport sometimes.
Osfspaghetti.res:
CONTAINER Osfspaghetti
NAME Osfspaghetti;
INCLUDE Obase;
GROUP ID_OBJECTPROPERTIES
LINK PYMESHLINK_MESH { ACCEPT {Opolygon;} }
Osfspaghetti.h:
#ifndef _Osfspaghetti_H_
#define _Osfspaghetti_H_
enum
PYMESHLINK_MESH = 10000
#endif
Osfspaghetti.str:
STRINGTABLE Osfspaghetti
Osfspaghetti "Spaghetti";
PYMESHLINK_MESH "Object";
SF-spaghetti.pyp
import math
import sys
import os
from c4d import plugins, utils, bitmaps
PLUGIN_ID = 1000001
class spaghettiData(plugins.TagData) :
def Execute(self, tag, doc, op, bt, priority, flags) :
if op.GetTypeName() != "Spline":
return c4d.EXECUTIONRESULT_OK
bc = tag.GetDataInstance()
mesh = bc.GetLink(c4d.PYMESHLINK_MESH)
if not mesh:
pCount = mesh.GetPointCount()
if mesh.GetDeformCache() is None:
points = mesh.GetAllPoints()
points = mesh.GetDeformCache().GetAllPoints()
if pCount != op.GetPointCount() :
op.ResizeObject(pCount)
MG = mesh.GetMg()
op.SetMg(MG)
op[c4d.SPLINEOBJECT_CLOSED] = True
for i,p in enumerate(points) :
op.SetPoint(i, p)
op.Message(c4d.MSG_UPDATE)
path, file = os.path.split(__file__)
bmp = bitmaps.BaseBitmap()
bmp.InitWith(os.path.join(path, "res", "spaghetti.tif"))
plugins.RegisterTagPlugin(id=PLUGIN_ID, str="SF-spaghetti",
g=spaghettiData,
description="Osfspaghetti", icon=bmp,
info=c4d.TAG_VISIBLE|c4d.TAG_EXPRESSION)
