When to refresh a deformer object?
On 01/03/2011 at 02:37, xxxxxxxx wrote:
Cinema 4D Version: 12
Platform: Windows ; Mac ;
In the descriptions of my deformer object, I have a link field. Now I want the deformer to be recalculated when the linked object is moved or changed. Currently, nothing happens. ModifyObject() is not called when I do something outside the deformer's hierarchy.I would try to add the linked object to a dependence list, but that doesn't work outside GetVirtualObjects().
Thanks for help!
Greetings,
Jack
On 01/03/2011 at 03:09, xxxxxxxx wrote:
Could you look for MSG_DESCRIPTION_CHECKUPDATE in the Message() and then refresh from there?
Or maybe continuously check to see if the BaseObject in your link field is not set to NULL, thus looking for a change in the linkfield..
~Shawn
On 01/03/2011 at 03:37, xxxxxxxx wrote:
You can check this in ObjectData::CheckDirty. It's called if the link changes.
Here an example:
void MyDeformer::CheckDirty(BaseObject *op, BaseDocument *doc) { if (!op || !doc) return; BaseContainer *bc = op->GetDataInstance(); if (!bc) return; ULONG dirtyness = 0; // Get linked object BaseObject *lop = (BaseObject* )bc->GetLink(MYDEFORMER_LINK, doc, Obase); if (!lop) return; dirtyness += lop->GetDirty(DIRTYFLAGS_MATRIX|DIRTYFLAGS_DATA); // lastlopdirty is member variable of type ULONG if (dirtyness != lastlopdirty) { lastlopdirty = dirtyness; op->SetDirty(DIRTYFLAGS_DATA); } }
Compare the dirty count and update accordingly (lastopdirty).
cheers,
Matthias
On 01/03/2011 at 03:46, xxxxxxxx wrote:
That works, thanks Matthias!
I'll propably add some walking-up-the-hierarchy to check if parent have been moved.Cheers,
Jack
