On 27/02/2011 at 14:26, xxxxxxxx wrote:
User Information: Cinema 4D Version: 12 Platform: Windows ; Language(s) : C++ ;
--------- I am trying to write and register an xpresso node plugin. Here is what I have so far. I am starting simple just to see if I can get something to compile. I am running in to a problem because under the GvRegisterOperatorPlugin() The fourth argument requires an allocation of some sort. I try MyClass->Alloc() but Alloc() is not a member of GvOperatorData().. Does anyone know what I should put there?
Thanks,
Shawn
#include "c4d.h" #include "c4d_operatordata.h" #include "myClass.h" class MyClass : public GvOperatorData{ public: virtual Bool Init(GeListNode* node); }; //Init Function Bool MyClass::Init(GeListNode *node){ return TRUE; } Bool RegisterMyClass(void){ return GvRegisterOperatorPlugin(ID_NPARTICLE_NODE, "MyClass", PLUGINFLAG_SMALLNODE, MyClass::Alloc(), "MyClass", 0, ID_GV_OPCLASS_TYPE_GENERAL, ID_GV_OPGROUP_TYPE_GENERAL, 0, AutoBitmap("MyClass.tif")); }
On 27/02/2011 at 14:37, xxxxxxxx wrote:
Maybe I can only repeat myself but search the forum. there is a full example available (if not several).
On 27/02/2011 at 15:33, xxxxxxxx wrote:
Maybe i wasn't clear. I HAVE searched the forums and all results show to use GvOperatorData::Alloc for that argument or more specifically the class which inherits GvOperatorData. I am doing that but it doesn't work.
I was trying to use this example:
https://plugincafe.maxon.net/topic/3916/3386_baseobjects-and-objectlinkports&KW=GvRegisterOperatorPlugin&PID=13868#13868
but the sdk for r12 says that there is no Alloc() in GvOperatorData. This is why I am asking.
On 27/02/2011 at 16:22, xxxxxxxx wrote:
Any other examples that use GvRegisterOperatorPlugin() use the GvOperatorData::Alloc() for that argument so My question is, has this changed in the SDK? Or is there a different way to do it?
On 27/02/2011 at 16:35, xxxxxxxx wrote:
Problem Solved.
My mistake.. I cut out too much when shelling out my simple example...
I left out... static NodeData* Alloc(void) { return gNew MyClass; }
to the class methods.
The problem is solved.
Proof still that my forum searching skills are still in tact.
